Innovate Wideband working, but not logging correctly
Old Jul 9, 2008 | 09:36 AM
Mellon Racing's Avatar
you have it displaying wb02 in logworks right?, make sure you're using the same com port with evoscan.
Old Jul 9, 2008 | 10:06 AM
shuttlegoose's Avatar
yeah i had it logging in logworks fine. it just that it didnt have any other parameters such as rpm or anything. im not sure if it would benefit my tuner just having an afr log in logworks without knowing what rpm and stuff i was at.
Old Jul 9, 2008 | 12:59 PM
FuelsResearch's Avatar
I had the same symptoms when trying to use Lc-1 w/ evoscan .99. The problem occurs when you plug into the lc-1's serial out while the unit is powered on. To fix: launch lm programmer and reset lc-1 to gasoline, 14.7:1. For some reason when plugging in w/ power on, the programmer sets it to a custom configuration hence the 3-4.xxx. If this is your problem, be sure to hook up all cables (openport, serial to usb) to car and laptop before powering the car.
Hope that fixes your prob, it fixed mine.
Old Jul 9, 2008 | 05:17 PM
alright ill give that a try
Old Jul 9, 2008 | 05:18 PM
wait, i understand plugging everything in before i give it power, but how do i configure it without giving it power???
Old Jul 10, 2008 | 09:02 AM
Hook everything up, then configure it following the LC-1 instruction manual. After configuration always have everything plugged in before starting the car.
Old Jul 10, 2008 | 09:54 PM
StreetEvo's Avatar
Basically, you plug everything in before you turn the car to the ON position(or however you have your power setup for the LC-1). Turn the power to the LC-1 on. From there, Open LM programmer. Using LM Programmer check to see that your sensor config is set to default. Once it is set to default you're good to go. Just make sure that the LC-1 is off every time you, plug-in to or, unplug from it.
Old Jul 11, 2008 | 01:59 AM
evo4mad's Avatar
make sure you are running evoscan v2.4 there is a lot more LC-1 support added.
Old Jul 11, 2008 | 04:24 PM
alright, so i tried doing the lm programmer thinger, seriously it took 50 tries for it to stay on 14.7, i would click on it and then it would just make up a custom number. then when it finally worked my lc-1 wouldn't read right at all, so now i have to do a free air calibration or something, im starting to get pretty pissed. alright ill keep trying everything.
Old Jul 12, 2008 | 05:58 PM
alright i just installed 2.4 and tried and its still not working right. i recalibrated the gauge in free air again becuase i messed it up with the lm programmer trying and finally getting it onto 14.7 now its reading at like 10.x im so pissed i really don't knwo what else to try. i can't configure it with the lm programmer without it making the lc-1 not read at all and then i have to do a free air calibration and im not trying to jack the car up everytime i try to fix it with the lm programmer.
Old Jul 12, 2008 | 06:31 PM
nothere's Avatar
sorry to hear you have so much problems with your system.
If I remember correctly you set the reading to gasoline. this can be done in logworks before after or during a log.
Since you are bound to use evoscan, might i suggest you get everything working in logworks first so you know where your issue is coming from.
open openport 1.3, select what you want to log, press log, and then open logworks, connect, {AND now you can adjust your afr reading from lambda or gasoline} and then start a real time log.
let us know if you can get that going.
Old Jul 12, 2008 | 06:56 PM
its reading fine in logworks. it has to be a problem with the lm programmer.
Old Aug 10, 2008 | 06:57 PM
vint21's Avatar
I'm having similar issues, wondering if you got your situation resolved?
Old Aug 11, 2008 | 07:09 PM
evo4mad's Avatar
I found the bug, I had commented out a line of code, and had put a TODO: next to it.. lol. Anybody wanna test it, my wife crashed my evo so I dont have a test vehicle with LC1? msn message me.
Old Aug 12, 2008 | 06:51 AM
Jumperalex's Avatar
your [cough] wife [gag] crashed [sputter] your [spew] evo?!?!?! My consolation on your divorce :O ok ok just kidding. Sorry to hear it, and I assume (and sincerly hope) she is OK.
