ecuflash 1.29 and 1.30 problem connecting
Old Jul 25, 2008 | 02:20 PM
bmojito's Avatar
ecuflash 1.29 and newer problem connecting
[10:59:03.471] This vehicle interface does not support needed features.
[10:59:03.471] unable to connect to vehicle interface.
this is what keeps happening. i have the cable plugged in key in on position and then i open ecuflash. and it just keeps doin the same thing.
Old Jul 25, 2008 | 02:33 PM
bmojito's Avatar
just to read the ecu do i need both pluggs connected? ie: obd port and the white one next to it? if so i dont have the connector for the white one is there any way around it or jump it?
Old Jul 25, 2008 | 04:35 PM
silver_evo's Avatar
no, you need the white jumper one to make the ecu enter diagnostic mode. also use only 1.29a, some tactrix cables dont work after 1.29a.
Old Jul 27, 2008 | 07:46 AM
todd6027's Avatar
iirc a wire from pin100 at the ecu to white plug if its three plug ecu ,,check the ecu pinouts
Old Jul 27, 2008 | 10:38 AM
MalibuJack's Avatar
Yes, just to read or write the ECU you must have the white DLC plug connected along with OBD-II
So the answer is both plugs must be connected (or at least diagnostic init pin needs to be if you don't have the DLC plug)
Old Jul 27, 2008 | 07:23 PM
bmojito's Avatar
so how to do go about this?
Old Jul 28, 2008 | 12:54 AM
todd6027's Avatar
as above
