Made a Boo Boo :-(
Old Jul 27, 2008 | 08:04 PM
05ah8james's Avatar
Made a Boo Boo :-(
I just installed my new turbo kit and flashed the tune over, however I did not write down my immobilizer code, so now the car will not start. I still have ecu flash open from when I did it. Is there a way to undo the rom change, or find my immobilizer. Again, I have not closed out the program since I did this.
If theres a way to unhook the immobilizer, thats fine as well, anything to get my car started.
Old Jul 27, 2008 | 08:10 PM
mrMTB's Avatar
I was reading over in the EcuFlash forum that there is an alternate ROM that 05 MR's are using with Tephra's v5. One of the things that I noted was that they had to remove the immobilizer code because of space constraints. Might get you running again.
Old Jul 27, 2008 | 08:20 PM
05ah8james's Avatar
more info please!!
Old Jul 27, 2008 | 08:26 PM
03RRVIII's Avatar
there is no way to undo the ECU ones you have flashed it with the new tune!
Old Jul 27, 2008 | 08:36 PM
05ah8james's Avatar
ok, so how can i fix this?
Old Jul 27, 2008 | 08:38 PM
streetvision's Avatar
you don't have the original rom saved
Old Jul 27, 2008 | 08:40 PM
scheides's Avatar
EvoM Moderator
Pretty much only option is to disable the immobilizer. Search the ecuflash forum on how to do this, I have it done on my 05, and have posted in the thread discussing it. If you cannot find it, PM me, I will help you.
Old Jul 27, 2008 | 08:47 PM
ExViTermini's Avatar
What he said. I had to do it on an evo9 ecu into an evo8 car. They just wouldn't jive, oh well, immob delete FTW!
Old Jul 27, 2008 | 08:55 PM
evo8426's Avatar
do you have any previous tunes saved on your computer for your car?
