TephraMOD V5.10
Old Jan 30, 2010 | 07:21 PM
  #1231
philr8's Avatar
Originally Posted by gfng
i cant find the lean spool on Evo 7 Ralliart Rom (Tephra V5.10) 90550001
Add this xml to your romdata/mitsi/evo folder, make sure to select yes when it ask you if you are sure if you want to replace the existing evo7base.xml
You then will be able to see the lean spool and ecu periphery options
Phil
File Type: zip
Old Jan 31, 2010 | 03:26 AM
  #1232
cossie1's Avatar
posted the xml you need on geekmapped
Old Jan 31, 2010 | 06:47 AM
  #1233
Gary@MellonRacing's Avatar
ok ill try that right now ,
Old Jan 31, 2010 | 07:11 AM
  #1234
nope still even , cant see lean spool nor do i have periphery options
what coulod it be ?? i can see everything else
Old Feb 17, 2010 | 01:54 AM
  #1235
SeanV's Avatar
Same problem here, I don't see any of the periphery bit options to turn off lean spool.
Does anyone have a xml file for 90550001 that shows the Periphery bits correctly?
Thx.
Old Feb 17, 2010 | 09:55 AM
  #1236
philr8's Avatar
Thx.
the xml I posted inthis topic is defined, I have no problems with it. Open it with note pad and you will see the ecu periphery is defined. Make sure you delete your old evo7base.xml first!
Old Feb 18, 2010 | 12:29 AM
  #1237
SeanV's Avatar
Thx very much, it worked perfectly.
Old Mar 26, 2010 | 02:37 PM
  #1238
Mellon Racing's Avatar
tested 9626009 fix2 seems to be working fine
Old Mar 26, 2010 | 03:04 PM
  #1239
philr8's Avatar
^^^^ +1
No issues with 96260009 on my JDM Evo 8 FQ, all is working and good! Love the launch and CEL on knock!
Old May 9, 2010 | 03:51 AM
  #1240
YaroRS's Avatar
guys, what rom should I use on evo 9 EDM 88840016 ?
Old May 9, 2010 | 11:19 AM
  #1241
rolly1818's Avatar
Registered User
^^ i say 8858 AUDM evo 9. i think there is V7 out as well for that rom
Old Sep 26, 2010 | 03:27 AM
  #1242
richyrich's Avatar
Anyone have the xml for 96260009???
I have one but its the SD version
Old Sep 26, 2010 | 03:36 AM
  #1243
grayw's Avatar
Have uploaded one to your other thread.
Old Sep 26, 2010 | 10:49 AM
  #1244
richyrich's Avatar
Cheers
Old Jan 18, 2011 | 12:06 AM
  #1245
05VIII's Avatar
hey guys. fairly new to all this but i have been reading and reading and reading. there is ALOT to take in.
but i have a quick question.
i have an evo 8 running the 96530006 rom.
i was just comparing it to my buddies recent tune with the 88590015 rom on his evo 9 and checking out all the differences between mivec vs non mivec.
i noticed the idle section in the 88590015 rom looks much more easier to work with. he only has
target minimum idle
target idle rpm with ac on#1
target idle rpm with ac on #2
etc etc
on my rom 96530006 rom i have
Desired ISCV intial step position with AC off-Neutral
Desired ISCV intial step position with AC off-Drive
Desired ISCV intial step position with AC on-Neutral
Desired Idle RPM-Neutral
Desired Idle RPM-Drive
etc etc..
should i just ignore the Drive tables and only focus on the neutral tables?
also, im currently having problems throwing p0505. all the searching points me to icsv steps being off from whats being demanded.
could i simply copy his settings and transfer them over to mine and see if it works? he has different values then i do and he doesnt have problems with p0505.
should also add that i have tried the sas mode in evoscan and turning the biss screw to around my target rpm. and its also a new iac so its not dirty
also, is there any reason some of his tables are named differently from mine?
TIA
