Fuel trims...again.
Old Aug 9, 2008 | 10:42 AM
Boostfiend's Avatar
Fuel trims...again.
Ok so I used a code that someone posted and it still won't log fuel trims, could this be an ECU issue? cable issue? anyone have any suggestions on what I should do?
Old Aug 9, 2008 | 12:38 PM
oldevodude's Avatar
Have you tried MitsuLogger or scantech to see if trims are moving in those apps? Try different software to see if your Evoscan is not logging or if it is your car. On my Vista laptop Evoscan simply stopeed logging trims they were all.1% and did not budge. I uninstalled Evoscan rebooted and reinstalled and this solved MY problem.
Good Luck
