Smoothing your tune with graphing
Old Aug 18, 2008 | 01:24 PM
  #106
Jumperalex's Avatar
Well I don't think too many "others" have used it. And when they did they must have only had the VIII's 19 rows. [shrug]
Ok so ... I will add two more rows. Can you tell me, are all your first 19 the same as the VIII's? Doesn't really matter so much as I'm just curious.
mmmm this will change things a tad in how I do the averaging on the edg cells. I'll have to have a check box to ignore those cells for the VIII owners otherwise it will risk averaging in a zero. [sigh]
Old Aug 18, 2008 | 01:39 PM
  #107
PessimiStick's Avatar
My stock IX ROM (88950015) has 20 load columns.
Edit: 20 for Fuel Maps, 21 for Timing.
Old Aug 18, 2008 | 01:54 PM
  #108
~BoOsTeR~'s Avatar
Well, the reason I asked how others were employing it, is because I have seen peeps with Evo VIII in their sig or 'drives' desig, post pics with load to 300. I'm not sure if they had done a load column mod or not, or if ecu's vary from one to the next in that regard.
Yes they are exactly the same from what I can tell, in relation to the worksheet, except where 260 ends, it continues to 280 and then 300.
No worries man, I have already found this worksheet light years more useful (and obviously quicker) than the cell by cell method I was using. We all appreciate your work and all the contributions of everyone.
Thanks again.
Old Aug 18, 2008 | 01:57 PM
  #109
~BoOsTeR~'s Avatar
Now if I could just figure out how to colorize my darn graphs, everything would be perfect. [mwah ha ha ha]
Old Aug 18, 2008 | 02:00 PM
  #110
And the V2 Spreadsheet only has 18 load colums, not 19, so IX's do have 2 more columns.
(Same for Timing, 19 on the sheet, 21 on IX ROMs.)
Old Aug 18, 2008 | 02:05 PM
  #111
Jim in Tucson's Avatar
BTW: how many times did you smooth do you think ... I'm hoping no more than 10 but I could do a couple of thousand to be crazy hehe)
I think around 12 passes. But I only have 10 fingers - sort of - so I lost count.
And that's my good hand!
Old Aug 18, 2008 | 02:43 PM
  #112
Jumperalex's Avatar
Yes but the REAL question is can you count to 21 with your pant on?
Ok so ... it looks like I have my work cut out for me.
So to be sure, right now the IX has 20 columns in the fuel map and 21 in the timing? or is it actually 21 and 21?
As for those VIII's that show load out to 300 what they are doing is cannibalizing the lower rows, shifting the map over, and then changing the last rows to represent 300. Much like people change the RPM points for the WGDC map these folks are changing the load points in their fuel and timing maps. Makes sense too since a few load points down low are nearly copies of each other so why keep it.
It might just be easier to have two tabs for each table size since the logic to turn on and off those last two rows will just get annoying. though I can think of a work around, for now, so I can add the rows and not screw it up for VIII owners while I work on v3 which is really going to be a big design change with the new multi-pass smoothing. Cause if Lefty up there needed 12 iterations (I question the actual need and rsult but to each their own) then I'm gonna really need to kick it up a notch.
Old Aug 18, 2008 | 02:46 PM
  #113
~BoOsTeR~'s Avatar
You're the man, dude. I'll be tuned in.
Jason.
Old Aug 18, 2008 | 03:27 PM
  #114
Jumperalex's Avatar
v2-1 EVO VI Version complete
Ok v2-1 EVO VI ONLY is done ... let me know if I missed something. Also added a quick instruction tab, feel free to add to it and post it for inclusion.
Old Aug 18, 2008 | 04:04 PM
  #115
cossie1's Avatar
Evo VI only ???
Old Aug 18, 2008 | 04:13 PM
  #116
Jumperalex's Avatar
because they have more load cells than the VIII. OTherwise they are the same. But I suppose, if the RSII has that many cells too than it is for that. So ... not VI only but "21 load cell version"
Old Aug 18, 2008 | 04:17 PM
  #117
nonschlont's Avatar
This looks Awesome, and I would really love to utilize this, but Im having an issue w/ my MS Office and Excell. I can log, but can NOT save, edit or use any of the functions... I am stumped as to what is wrong... I recently purchased my first laptop, had a buddy install MS Office, but wasnt a valid copy, so I had my GF use the Business disc (which I know for a fact id valid) and still no go... any ideas???
Obvioulsy Im a newb to comps. and in need of a lil assistance...
TIA
Jumperalex/Jack_of_Trades... you guys rock!
TIA
Old Aug 18, 2008 | 04:23 PM
  #118
cossie1's Avatar
Sorry I must have missed something on this thread.
As afaik only the evo IX has 21 load cells.
I use an evo 7 ecu anyhow so it doesn't matter to me, but as there is no way to write to an Evo VI ecu with ecuflash at the moment, I didn't think anyone would be trying to smooth maps for an Evo VI.
Old Aug 18, 2008 | 04:51 PM
  #119
Yes but the REAL question is can you count to 21 with your pants on?
Not a chance.
Maybe I didn't NEED 12 iterations. In fact, my wife even claims I don't NEED an EVO. Obviously, she is mistaken.
I agree on the tabs. Separate tabs for the VIII and the IX would be much easier to implement and cleaner in appearance as well...me thinks.
(Did you write VI when you meant IX?)
Old Aug 18, 2008 | 05:34 PM
  #120
Evoryder's Avatar
TIA
TIA
complete uninstall then reinstall the business disc. Also if that doesn't work you can use free excel based program from www.openoffice.org
Jeff
