How to tell if your tuner ripped you off
a factory scaled maps dont mean its a 1/2 *** job. You can get a wonderful tune using them. It all depends on the car since everyone is a little different. If your tuning philosophy is to tune on the ragged edge then ya you probably need to adjust the resolution in some areas. But this is a pretty good idea for a thread. good job on starting it up.
another way tuner could rip somebody off is if they spent say $25k on a car being built & it ends up running SLOWER than it did with stock turbo. seems to be the trend in AZ. down there big turbo means slow
Honestly, this thread is horrible. Every single point that you made is VERY conditional, and I don't think any of them apply to tuning a fully stock car (which is very beneficial)
Everyone has different needs, these may be clues that your tuner didn't know exactly what was going on... but there are also instances where you are just paying for a full boost tune, not a street tune, etc, etc, etc.
Did you guys know that some of the roms (88950015) have higher timing in the high load, low octane maps than the high load, high octane maps? Did you know that boost cut can be valuable, but some people just don't want it? Did you ever think that sometimes people might want high and low octane maps that were the same?
It is not at all required to log the 2 byte values to tune properly. It is totally possible to tune a car very well with the stock MUT table
While not generally preferential some drastic changes even occur in the stock fuel and timing maps... big surprise!
Some people also want higher resolution in their low load cells. Cars that are daily driven but heavily modded probably find this particularly valuable. This, just like most everything else in here can be user/tuner preference and is not necessarily a sign of someone who doesn't know what they are doing.
Just about the only thing that you said that is generally correct is about the scaled injectors... but only applies if you have non-stock injectors. Maf scaling is not necessary either, or my car that is definitely in your "requires maf scaling" category wouldn't run perfect on fresh power and start with the stock table.
You should add a whole lot of "ifs" to your post or just remove it. I can't even imagine the headache you just created for some poor, professional, awesome tuners who are doing a perfectly good job.
What you are saying is similar to saying you need to replace a whole car if the engine goes bad. Sometimes, (and very often for that matter) the things that you have mentioned are not indicative of a bad tune in any way!
Good points, and I know where you are coming from..Most of the big money guys can't be bothered with stuff like this but at the same time it is not always necessary and there are ways around it. But I would never tune without a solid log to point me where I need to be, as I have seen some people do..I have seen some really bad things lol
Setting the timing maps the same is not lazy. There are reasons that we are beginning to understand more and more the deeper we dig.
The fuel map you have has violent changes becuase of the lean spool being on. You didnt know what it would look like but that doesnt make it lame.
If we are gonna get on this topic, any tuner that doesnt include a knocklight must be lame too? Its a nice safety feature for the end user but hardly needed for 20psi tunes on a mostly stock turbo.
The conclusions you make have nothing to do with lazy. Most people dont need all the TOP FUEL mods to a ROM becuase they have a mild build that isnt on the edge.
Thanks for the post r3compile, it's very informative for people such as me who don't know how to tune via Ecuflash.
Can you read an Ecutek tune with the above equipment as I would like to understand my settings & to be able to view logs & datalog my vehicle at some stage? I'm not sure whether the ecu can be locked via ecutek, can anyone put some light on this?
Thanks all.
Steve
Thanks all.
Steve
