My first log, What do you think?
Old Sep 23, 2008 | 02:15 PM
pupo's Avatar
This is my first log 2005 evo 8 GRS, mods so far are MR JDM d/v, that is it. What do you guys think? I am logging the right things? I am using EvoScan 2.5 for loging, I added the mut tables to my .xml files with a few other things that I saw on other threads.
Old Sep 23, 2008 | 02:22 PM
DxbIX's Avatar
at no point did you go WOT, you need to push the car to its limit to see if there are issues, no point babyfooting the car around
Old Sep 23, 2008 | 02:56 PM
pupo's Avatar
I tried to but there was a a bit of traffic, I am just trying to find out if I am logging the right things, I will be adding a TBE from Cobb tunning later, I want to see how the car is before and after. My next log I will go WOT.
Old Sep 23, 2008 | 05:09 PM
cfdfireman1's Avatar
Knock free.
Old Sep 24, 2008 | 02:35 AM
BCOZEVO's Avatar
Get a wideband ASAP and start logging that as well. Also the 2byte mods would be a good idea if you have a flash cable.
When logging I get into 3rd gear at about 2000RPM for about 10-15 sec then push the petal to the metal all the way to redline then shift to 4th and sometimes 5th gear depending on how much time I have to reach over and hit stop logging.
Practice makes perfect! Keep it up.
