EvoScan 2.5 fixs
Old Sep 30, 2008 | 08:27 PM
nonschlont's Avatar
EvoScan 2.5 probs/fixs
Well since Im having issues (multiple) I figured I would start this thread to source out the fixs.
Ok heres my problem... I was using 2.1 w/ out any flaws, but installed a ZT-2 yesterday and I liked the new "COM port" feature inside the Evoscan program, so I installed 2.5. Heres where my prob begins... I do NOT have any of the corresponding files that come w/ Evoscan... example: saved data files, data .xml file, drivers, etc. All that I get is "windows installer package", "set up application" and the Evoscan program itself that I copied from the "start window"... I have re-done this procedure 4 times myself, and once yesterday by the installer.
I was also having the issue of Evoscan not connecting w/ the "external WB afr" but fixed that, as many people have encountered the COM port issue. Make sure the COM ports in Evoscan and Zeitronix usb cable match!
If I dont have any of the files that come w/ evoscan (saved data logs) how do I look @ my logs? If I wanted to edit my .xml for the front and rear 02 patch, how would I do that? ETC.
Edit: after actually playing w/ the program a bit, it seems like its all in the main screen of the program... well done!
