fed up with knock control
Old Nov 25, 2008 | 12:49 PM
  #361
DCsleeper's Avatar
Yes it is also knocking if I rev the motor up also, seeing about 9-12 counts.
any ideas? Maybe something sensor related?
I too have this issue and see knock counts in the 36 range. There are no abnomal sounds or vibration, compression tested within spec, and there are no exhaust rubbing issues.
Today, I started testing the newly found knock table show above and it has been successful in eliminating the effects of drasticly pulling timing due to high knock sensor readings at these low load levels.
I have no issues with knock at any higher load levels (a.k.a anything above 120).
Old Nov 25, 2008 | 06:27 PM
  #362
lan_evo_mr9's Avatar
knock sucks
Old Nov 27, 2008 | 03:00 PM
  #363
honki24's Avatar
lol, crack kills.
Jesus saves.
Old Dec 16, 2008 | 12:03 AM
  #364
tephra's Avatar
ok dudes - now that jcsbanks has done some wunderful works on the knock routines is this patch still needed?
I am just trying to finalise changes in V6 so I can get to work on testing and what not
Old Dec 16, 2008 | 03:29 AM
  #365
cossie1's Avatar
I don't think it is something that is needed so much now, but as you have done all the hardwork, it would be nice to have the option for a little more flexibility imo
Old Dec 16, 2008 | 04:38 AM
  #366
jcsbanks's Avatar
I wouldn't favour (favor) bolting on modifications to quite a clever sytem that already works well and is now configurable.
Old Dec 16, 2008 | 04:45 AM
  #367
tephra's Avatar
So John - you are confident that phantom knock can be cured now?
Looks like there isn't a need for this mod if that's the case. I prefer it that way, V6 is starting to get a bit out of hand hehe
Old Dec 16, 2008 | 04:59 AM
  #368
jcsbanks's Avatar
We can tackle it with the noise thresholds by RPM, and the load thresholds by RPM. If these can't fix it, I don't think it can be fixed.
Old Dec 16, 2008 | 06:57 AM
  #369
Mellon Racing's Avatar
I'd prefer that it was condensed into one tepra ROM to keep it simple
Old Dec 16, 2008 | 07:51 AM
  #370
jcsbanks's Avatar
Chris, you're asking for Tephra to rewrite the knock control routines to do something they do already, or are you just asking him to add the definition information to his xml?
Old Dec 16, 2008 | 07:54 AM
  #371
justboosted02's Avatar
this mod isnt needed, the table that jcsbanks work perfectly and make it possible to control knock very well
Old Dec 16, 2008 | 09:45 AM
  #372
Old Dec 16, 2008 | 01:25 PM
  #373
tephra's Avatar
The def's will slowly be included in new ecuflash releases - once they get done by ppl
axxevo8
Nov 12, 2015 11:43 AM
awdordie
Apr 2, 2012 10:31 PM
DCsleeper
May 7, 2008 01:14 PM
shiv@vishnu
213
Aug 5, 2005 03:05 PM
