FIC 750's scaling and latency issues and THE MEGA FIC 750 thread (hopefully)
Old Feb 23, 2009 | 05:07 AM
Appauldd's Avatar
750 Injectors
Scaling 650
3.312
1.680
1.032
.864
.648
.552
.360
I put in the 650 scaling above and the mid trim at cruise is nearly perfect. +1.23. BUT, low trim still won't adjust for me. It stays on "0".
Another strange thing I am getting is that after the car is driven and warmed up it won't hold idle. It wants to go full rich and die. If I let it sit for a while it eventually stabilizes to idle again. Then the mid fuel trim that was perfect at cruise is now -11.56 but the car will idle. Low still hasn't moved.
As I start cruising again mid trim will go back to +1.23 or so and hold steady. I roll to a stop and just as before the car wants to go full rich and stall. After a while it will stabilize but the mid trim, yet again, goes to around -11. And still "0" on the low trim.
What gives.
Old Feb 23, 2009 | 08:06 AM
Pr3z's Avatar
This has been an issue for me as well going to try these new scaling at 650 numbers...
Old Feb 23, 2009 | 01:41 PM
Fast_Freddie's Avatar
Veteran: Navy
Originally Posted by Appauldd
750 Injectors
Scaling 650
3.312
1.680
1.032
.864
.648
.552
.360
What gives.
You may want to try and disconnect your battery for about 30 seconds, reconnect, let the car warm up for about 10 minutes, start logging at idle for about 15 minutes, go drive for about 20-30 minutes, then let it idle again for about 15 minutes and see where you are at...
Old Feb 23, 2009 | 01:43 PM
Veteran: Navy
Remember guys if you have an EVO 8 if you make any scaling/latency changes you need to disconnect the battery for about 30 seconds to reset the fuel trims, as flashing alone will not reset the fuel trims like an EVO IX.
Old Feb 23, 2009 | 03:54 PM
SWOLN's Avatar
Scaling 650
4.69v- 3.312
7.03v- 1.680
9.38v- 1.032
11.72v- .864
14.06v- .720 ...could be the cams I dunno.
16.41v- .552
18.68v- .360
Low = 11.2
Mid = -.290
High = .1008
What voltage to fix the "Low"?
Thanks
Old Feb 24, 2009 | 10:33 AM
steadly2004's Avatar
Originally Posted by SWOLN
Scaling 650
4.69v- 3.312
7.03v- 1.680
9.38v- 1.032
11.72v- .864
16.41v- .552
18.68v- .360
Low = 11.2
Mid = -.290
High = .1008
Thanks
Should be the 11.72, make the latency about 0.1 higher and see where it gets you.
Also realize that at idle you may be at ~12.5v-13v and not 11.72v and that any changes at the actual idle voltage will be averaged between the 11.72 and 14.06 range. It interpolates between the different numbers.
To be sure you can just look at evoscan during idle when the trims are adjusting, and see where the voltage sits at during those adjustments.
Old Feb 27, 2009 | 08:22 PM
SWOLN's Avatar
Scaling 650
4.69v- 3.312
7.03v- 1.680
9.38v- 1.032
11.72v- 1.008
14.06v- .720
16.41v- .552
18.68v- .360
Low = 5.22
Mid = -.290
High = .1008
So I checked my idle and I'm at about 14.1-13.8v. That's good I think. Also, I changed the above 11.72v to 1.008, but I see that my 11.72v is very close to my 9.38v. I now am wondering when am I at 9.38v, and do I need to space that voltage farther apart from the 11.72v?
Also, is it my cam duration thats throwing my number off of the normal posted numbers like John Bradleys ?
Thanks again.
Old Dec 9, 2014 | 04:50 PM
jameswwt's Avatar
Hi Guys, sorry to bring up this old post again but im wondering how update is the FIC 750cc Injectors Scaling & Latency here now?
Should i follow the Latency table from FIC or Mr John Bradly?
Thanks
Old Dec 10, 2014 | 08:12 AM
SWOLN's Avatar
It would be outside the norm if "JohnBradley"s' numbers were off.
Old Dec 10, 2014 | 04:05 PM
jameswwt's Avatar
Old Dec 13, 2014 | 03:33 AM
jameswwt's Avatar
Update : FIC 750cc Injector - Latency & Scaling
Using FIC latency table = Car AF/R - 11.5-12.5
Using John Bradley latency table = Car AF/R - 14-15.5 Superb!
(I adjusted the SD VE% table on the lower load to get it further leaner a bit)
Car just a little hesitation to fire up even engine is fully warm up.
Any idea on how to improve the engine start up?
Old Dec 22, 2014 | 12:37 AM
jameswwt's Avatar
Hi Guys,
im having some problem with my idling as initially my 14.5-1.57AFR range with Mr JohnBradly latency table but now duno why its suddenly go extremely lean 17-18+AFR? Tried increase the latency % little by little but its either extremely Rich or Extremely Lean.
Latency table by JohnBradly vs FIC table.
JB = Very Lean / FIC = Very Rich 11.2-12.5Afr
Using JB table the car afr is very lean and the rpm is low (900-1000)
Using FIC table the car afr very rich but rpm is (1000-1200)
What can i do? Can i tweak on the SD VE %?
Thanks
Fast_Freddie
Oct 30, 2023 01:56 AM
bez_bashni
Apr 5, 2016 11:16 AM
turbotaloon95
Aug 7, 2014 04:41 AM
Sirnixalot
Feb 12, 2012 04:44 PM
