EvoScan 2.5 not showing values under Map Tracer feature. Any ideas?
Old Nov 5, 2008 | 06:53 AM
joedr's Avatar
EvoM Moderator
Question EvoScan 2.5 not showing values under Map Tracer feature. Any ideas?
All,
I ran into a situation where the Map Tracing is not displaying the selected values once the *.csv is loaded and any of the logged items are selected.
Can somebody review the attached log and Data.xml and see if there is anything wrong? Any idea why the values are not showing on the Map Trace?
I am using EvoScan 2.5.
File Type: zip
Old Nov 5, 2008 | 08:00 AM
lapulapu's Avatar
i ran into a similar situation. My solution was to not log 1byte Load.
Old Nov 5, 2008 | 10:54 AM
joedr's Avatar
EvoM Moderator
Huuum! I am not logging any other load parameter with the exception of LoadMUT2Byte.
Any other idea?
Old Nov 9, 2008 | 05:40 AM
joedr's Avatar
EvoM Moderator
Bump! Just can not figured out why the values are not showing.
Old Nov 12, 2008 | 04:26 AM
evo4mad's Avatar
give this new beta version a shot. let me know of any issues straight away, thanks.
www.limitless.co.nz/evoscan/EvoScanUPGRADEv2.6beta4.zip
Old Nov 12, 2008 | 05:15 AM
joedr's Avatar
EvoM Moderator
Thumbs up
It works now!
We lost the ability to use the XML file to define the fuel and IGN tables. Before, Evoscan asked for the XML to define the tables. On this one, you select only the *.bin or *.hex and it is enough.
Looks good! Thanks for the update!
I will look for any errors and post back any findings. I should be using Evoscan this weekend on a tuning session. Keep you posted!
