Evoscan not connecting.
Old Nov 27, 2008 | 06:33 PM
brandEvO's Avatar
I've asked this several places but nobody seems to have any answers. I can't get Evoscan to connect. It checks the DTCs, but won't log. I've tried everything, other laptops with different versions of Evoscan and nothing works. ECUflash works great, just not Evoscan. One thing I figured was that the autoconnect wideband is checked and I can't uncheck it. Also theres no way to undot where it has what wideband I have (I have a wideband, but can't get the usb/serial adapter to work, Vista FTL!). If any of you tuning geniuses can steer me to any ideas or direction would be amazing. I'm getting a custom tune in Jan. and I want to make sure everything it working. Thanks.
Old Nov 27, 2008 | 06:52 PM
tephra's Avatar
make sure "External Wideband A/F Ratio" is UNTICKED.
if that doesn't work then get evoscan2.5 and install it.
then overwrite the exe with the one from the evoscan2.6 thread (beta 6 i think its at)
Old Nov 27, 2008 | 06:59 PM
brandEvO's Avatar
I don't even see where it has External Wideband A/F Ratio to untick. It has everything else.
Old Nov 27, 2008 | 07:00 PM
tephra's Avatar
In the main list... it might be called something else.
Look for "WDB" in the request column.
what version u running?
Old Nov 27, 2008 | 07:04 PM
brandEvO's Avatar
v 2.6 beta and I found the wideband, it was under SSMI. I always forget about that one. But it was already unchecked.
Old Nov 27, 2008 | 07:10 PM
tephra's Avatar
what error do you get when it connects?
Old Nov 27, 2008 | 07:15 PM
brandEvO's Avatar
I don't remember seeing an error code, I just let somebody borrow my tactrix cable so I can't go check it, but is it possible it didn't even show an error. It just keeps trying to reconnect.
Old Nov 27, 2008 | 07:16 PM
tephra's Avatar
well when you get the cable back, just see what the error/message is...
Old Dec 11, 2008 | 09:17 AM
brandEvO's Avatar
I figured out what the problem is. I own an RS and the ABS stuff was clicked. Solved the problem.
Old Dec 11, 2008 | 09:24 AM
555R's Avatar
i cant get v2.5 to connect i get a really long error message
thread failed during processing
it will open but wont do a damn thing
Old Dec 12, 2008 | 06:35 PM
brandEvO's Avatar
do you have Vista?
Jim in Tucson
Nov 5, 2022 06:37 PM
kyoo
Jun 30, 2019 12:44 AM
UxC
Dec 19, 2016 08:43 AM
evo jason
Jan 7, 2012 04:25 AM
AlwaysinBoost
Sep 14, 2009 01:01 PM
