AFR's Evoscan vs Logworks
Old Dec 2, 2008 | 01:44 PM
sponners's Avatar
Hi all,
I find that my afr's are upto 1 point leaner in evoscan than they are in logworks!
has anyone else noticed this? what is the reason for it?
....I'm going by the readings in logworks (v2).
.....also how do I configure logworks for rpm against afr.
cheers.
Mark.
Old Dec 2, 2008 | 06:20 PM
C6C6CH3vo's Avatar
At one time EvoScan did not completely parse the instrument's packets causing weird values. Not sure if the newer ones are like this too and values may be way off instead.
Are your readings consistantly different every time and by how much?
For an X-Y log in the view tab (I think) just select O2 as primary axis and rpm (or whatever) as secondary
