Open Loop > Matt55
Old Dec 31, 2008 | 06:45 AM
matt55's Avatar
Open Loop > Matt55
I Cant get my to car to do any thing higher than 14.6 A/F in openloop .
In closed loop it runs 14.5-15.0 A/F
Here is a map I tried last night and still got 14.2-14.6 from -20" up to -2'' vac
Ive messed around with the "Open loop throttle Lo and Hi" and it dosnt really change anything at all .
With the "Open loop load" # I can tell when it goes from Open loop to closed loop (45 load = -10" , 10 load = -20" -/+) but no matter the number i put itn the map it still run 14- 14.6 , but no higher .
Any Ideas what Iam doing wrong ?
Old Dec 31, 2008 | 08:35 AM
wreckleford's Avatar
Maybe some other ocnditions are keeping it in closed loop. Increase the min coolant temp for closed loop to a value higher than your max coolant temps and see if it runs open loop then. I have done this before and it runs open loop.
Old Dec 31, 2008 | 01:39 PM
matt55's Avatar
It is going in to open loop (I think) just it will not hit the valves Iam ask for .
Old Jan 2, 2009 | 09:16 AM
matt55's Avatar
Here is a log of "open loop load set" at 45 and something like 15.9 A/F's in da map
When its in "closed loop" the A/F oscillate from 14.2 up to 15.1 .
Old Jan 2, 2009 | 02:24 PM
andrewzaragoza's Avatar
i believe there is a mod wherein you can modify you closed loop afr. that would be much easier that what you are trying to do.
Old Jan 2, 2009 | 05:45 PM
nothere's Avatar
ask for more and maybe you will get what you want.
Old Jan 2, 2009 | 08:55 PM
fostytou's Avatar
EvoM Community Team
Yeah Matt.... It seems like you are trying to "trick" the ECU but have a wideband installed. If you have an analog out on the wb MRFred's fuel control mod might be for you.
