what logging software is this from?
Old Feb 16, 2009 | 01:50 PM
leecavturbo's Avatar
evoscan x.x?
Old Feb 16, 2009 | 01:51 PM
inco9nito99's Avatar
Innovative LC1?
Old Feb 16, 2009 | 01:56 PM
Originally Posted by inco9nito99
Innovative LC1?
ah logworks
how does logworks get engine data?
Old Feb 16, 2009 | 02:46 PM
logic's Avatar
Yep, that's Innovate's Logworks.
You can add an logging source to Logworks for data read via MUT from an Ecuflash-compatible cable. Basically, you just fire up a separate program (which comes with logworks), define the MUT values you want to poll from the ECU (similarly to how you might do it with Mitsulogger or Evoscan, there's a configuration file that defines different loggable values), and then fire up Logworks. It'll then poll the ECU and the wideband for data.
Old Feb 16, 2009 | 04:00 PM
nothere's Avatar
logworks picks up about a dozen engine parameters through the ecuflash/evoscan cable and displays them along with whatever innovate sensors you might have.
really nice logger software.
you can add more ecu data if you know how to speak the language.
Old Feb 16, 2009 | 04:01 PM
cool
tactrix cable work or not?
any guides on how you define what you want?
Old Feb 16, 2009 | 04:03 PM
Originally Posted by nothere
l
yeah i particularly like the 3d graphs and general look / features
Old Feb 16, 2009 | 05:59 PM
justboosted02's Avatar
logworks is a great program, i used to use it before i got evoscan. evoscan logs faster
Old Feb 17, 2009 | 03:54 AM
only thing i don't like about evoscan is the graph doesn't scale each parameter.
i.e logging knock and rpm then the scale you'd want for that would be say 0 - 12
and the rpm scale 0 to 8000 on the same graph. get me?
or do i have some thing setup wrong with evo scan?
rpm reports in a scale 0 - 80 and wideband upto 600 ?
Old Feb 17, 2009 | 04:44 AM
here is my evoscan log of essentially a run the same as the logworks example
but the log works is so easy to see whats going on.
for instance tps in logworks when at 100% is across the top of the graph whilst in evoscan its just under halfway. so it looks like evoscan picks the highest reading and uses that as the Y axis scale which doesn't give good resolution to readings with very low numbers like knock and afr!
this is how the scales should be imo.
fearD.evo
Aug 8, 2013 11:13 AM
Yousef
Mar 29, 2010 02:38 PM
mmartahus
May 4, 2009 09:50 AM
Talon_66
16
Dec 26, 2008 09:18 PM
BCOZEVO
Feb 16, 2008 11:24 AM
