Knock Control Settings/Loads
Old Feb 16, 2009 | 02:45 PM
Dragon-V's Avatar
Hi,
Been looking at the following and wondered if someone can shed some light on how it all works.... i.e if you increase the load on the multiplier its more prone to remove / cancel out the detection of knock? If my assumption is correct the reason the mid range RPM had a multiplier of 61 and you up'd it to 65 for example that when the Cam duration changes the chance of it detecting the random knock would be less and if number was lower than 61 the chance is increased?
See below image.....
Discuss
Cheers
Lee
Old Feb 16, 2009 | 05:29 PM
Thoe99's Avatar
Yes, the higher the multiplier, the less knock gets registered. However, please don't raise it to 65 :O
