1 byte load not right?
Old Feb 24, 2009 | 10:48 AM
leecavturbo's Avatar
my 1 byte load goes to 255 and holds it pefectly while on boost.
its as if my load is higher but whatever scale or setting there is it will only record a max of 255!
Old Feb 24, 2009 | 11:41 AM
raasfaas's Avatar
Is it just me or are you not logging 1 byte load?
1 byte load is an additional patch that you need.
https://www.evolutionm.net/forums/ec...d-v5-10-a.html
Old Feb 24, 2009 | 01:33 PM
yeh its patched. i think. column after calc load no?
Old Feb 24, 2009 | 01:55 PM
raasfaas's Avatar
No that's load11bit, its not the same. After you do the patch it should look something like this:
Old Feb 24, 2009 | 03:15 PM
Thx^
i'll get the patched checked.
speed is also not reporting(logging) correctly is that a common problem yet to be resolved?
Old Feb 24, 2009 | 03:20 PM
rallykid's Avatar
why wouldnt everyone just log 2byte?
Old Feb 24, 2009 | 03:25 PM
i dunno is the patch anymore complex? or not available on my rom?
Old Feb 24, 2009 | 03:58 PM
tephra's Avatar
2byte requires some setup in the ROM - 1byte only requires using my mod rom and adding the 1byte load to evoscan..
2byte also consumes more logging speed
2byte is also prone to high/low byte mismatch - ie your graph has incorrect peaks/troughs.
Old Feb 24, 2009 | 04:44 PM
THUB's Avatar
I get those crazy peaks all the time in two byte. I thought my car was actually freaking out at first.
