EvoScan error, please help!
Old Mar 31, 2009 | 08:09 PM
Appauldd's Avatar
Glad to see I am not the only one to have issues with the EvoScan "dyno"
Old Mar 31, 2009 | 08:29 PM
lemmonhead's Avatar
hey it only cost $25 right, you get a lot for such little money. you are not going to get everything for nothing come on and just be happy with an amazing gift.
Old Mar 31, 2009 | 08:33 PM
Appauldd's Avatar
Comments like this do nothing to promote making a great product even better.
I am absolutly pleased with all that EvoScan can do. If there is an error though, why not address it?
If I knew how to code....I would work on it myself and give the information to everyone else. We are all trying to help one another.
Old Mar 31, 2009 | 09:14 PM
fostytou's Avatar
EvoM Community Team
Originally Posted by Appauldd
Yes I am logging the 2 byte load, as for the the calls and altnames?
If you look back through the altnames and calls, by default:
Estimated tq calls the altname [WHP]
Estimated wheel horsepower [WHP] calls altname [LbsMin]
Estimated lbs/min calls [gRev]
Estimated g/rev calls [LoadCalc] by default
If you have a more accurate way of logging g/rev you can skip the last step and have the other functions call your more accurate way to calculate g/rev. If not, you can have estimated g/rev call your 1 byte load or 2 byte load altname for its calc function.
This should [at least in theory] give you a much more accurate calculation.
Old Mar 31, 2009 | 09:22 PM
Appauldd's Avatar
This is what I have.....
<DataListItem DataLog="N" Color="" Display="Estimated g/rev" LogReference="gRev" RequestID="CALC" Eval="[LoadMUT2Byte]/95" Unit="g/Rev" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="12" ChartMin="0" ChartMax="12" ScalingFactor="1" Notes="If you are using the Load MUT 2Byte Mod, you can double click this item, and edit the Function to be: [LoadMUT2Byte]/95&#xD;&#xA;&#xD;&#xA;If RequestID contains more than 2 characters, i.e. CALC, then there is a keep alive request sent to the vehicle ecu while this gets calculated." Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Estimated Lbs/min" LogReference="LbsMin" RequestID="21" Eval="([gRev]*x)/454" Unit="lbs" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="65" ChartMin="0" ChartMax="65" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Estimated Horsepower" LogReference="WHP" RequestID="CALC" Eval="[LbsMin]*9.15" Unit="Whp" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="1000" ChartMin="0" ChartMax="1000" ScalingFactor="1" Notes="If RequestID contains more than 2 characters, i.e. CALC, then there is a keep alive request sent to the vehicle ecu while this gets calculated." Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Estimated Torque" LogReference="Lbsft" RequestID="21" Eval="([WHP]*5252/x)" Unit="lbsft" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="1000" ChartMin="0" ChartMax="1000" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
This "should" be accurate. I think?
Raceghost
Jul 29, 2016 12:04 PM
Rpf1evolution
Oct 14, 2013 08:03 AM
mrfred
Jun 16, 2009 03:02 PM
PeteyTurbo
Jun 25, 2008 02:17 PM
