Easy speed density? First test...
Old Mar 2, 2009 | 09:06 AM
4kinboost's Avatar
Jscbanks-- You are awesome!!
Old Mar 2, 2009 | 09:11 AM
leecavturbo's Avatar
Originally Posted by jcsbanks
the end result is a very neat mapping arrangement where 0 PSI gives you 100 load, 14.5 PSI gives you 200 load, 29 PSI gives you 300 load.
now that is what i'm used to with aftermarket
Old Mar 2, 2009 | 01:02 PM
jcsbanks's Avatar
Pictures show my new MAF smoothing table and you can see in "fuel" the small changes I made to some of the load axis - this is because the MAF smoothing table only affects the IPW calculation, not the load lookup, so if you want the right AFR to be looked up this is the quick and dirty method. Even without it wouldn't be wildly out.
Also attached is a spreadsheet screen grab showing the scaling, smoothing and combination of the two. We could simplify the smoothing and scaling tables into one simple master VE table which would be your only calibration for the speed density patch.
There are many possibilities, I don't want to confuse. If you want a tested version, stick to the main thread.
Attached Thumbnails Easy speed density? First test...-mafsmoothing.png   Easy speed density? First test...-fuel.png   Easy speed density? First test...-ve.png
Old Mar 2, 2009 | 01:08 PM
cossie1's Avatar
Is your maf smoothing table reading Airflow HZ and unit8 ?
Old Mar 2, 2009 | 01:28 PM
jcsbanks's Avatar
Airflow Hz and percent128 (x/1.28)
Old Mar 2, 2009 | 01:40 PM
cossie1's Avatar
Ok what address do you have for the maf smoothing table on your rom, as when I convert to airflow hz it doesn't look correct.
Old Mar 2, 2009 | 02:15 PM
jcsbanks's Avatar
Old Mar 2, 2009 | 02:21 PM
cossie1's Avatar
Ok changed it to airflow16 (not airflow HZ) and it still doesn't display correctly for some reason.
Address's are the same as yours though
EDIT:
Sorted it, the scaling wasn't correct in my evo9base for some reason it was set to x/6.24 instead of x/10.24
However it's only giving me to the nearest 1.
i.e the first in the list is 19 and not 18.8
Old Mar 2, 2009 | 02:36 PM
jcsbanks's Avatar
That needs a change to %.1f in the scaling to give it 1 decimal place.
Old Mar 2, 2009 | 02:42 PM
esevo's Avatar
This is great! I cant wait to try it, however I dont have MAF smoothing table in ecuflash?
Old Mar 2, 2009 | 02:43 PM
cossie1's Avatar
Sorted now it makes sense
But why are the colours not changing for the higher values ???
Old Mar 2, 2009 | 03:00 PM
jcsbanks's Avatar
I'm going to kick your **** across the intarweb cossie1
esevo, could be your user level, change to developer.
Old Mar 2, 2009 | 03:02 PM
cossie1's Avatar
What did I do ???
I was just about to ask how I should rescale my load for the fuel map seeing as I have 2 less load sites than you do
Old Mar 2, 2009 | 03:03 PM
esevo's Avatar
It is in Developer??? I have Maf Compensation but not Maf smoothing
Old Mar 2, 2009 | 03:19 PM
jcsbanks's Avatar
cossie1, you asked about colo(u)rs Re your fuel map - if your load at low levels (say 40) has lost its approx 80% VE correction (because we flattened the VE tables), then we'll be moving the load site accessed from 40 to 50 (ie 50kPa is now 50 load, used to be about 40 load). By the time we get to about 130 load we would have about 100% VE anyway, so no further rescaling. You don't need a huge map, just scale it for where you need the changes. Or even just leave the load scaling along and rewrite the contents - this is the "my MAF readings were so screwed up I decided to start again" thread after all?
esevo, can you post a pic of what you have? It may be that someone clever took out the smoothing table as it never used to look very useful.
Both - it might be that we should combine these two tables into one easy to understand VE map then you would have the freedom to rescale. I'll think about it in my sleep and post again tomorrow
