No Low load LTFT on 272s and 1000cc injectors!
Old Mar 14, 2009 | 06:40 PM
ITP's Avatar
ITP
Hi,
The car is an 05 running 96940011. It has a built 2.0,HKS 272's,Rc1000cc,open filter with 3in turbo inlet pipe going to a 35R.
I have a issue with no LTFT in the "low load" datalog. Even at idle, the "mid load" will change. Car idles at about 50hz at 900rpm with about -13inches of vaccuum. I am assuming that this is enough airflow to put it out of range just enough to not be in the "low load" state. If this is the case. I'm fine with that. Although I'd really like to be able to use all 3 LTFT ranges.
Does anyone know what airflow ranges determine which trim range the ecu uses? And if they are able to be changed? I have seen no maps for changing these ranges.
I think this car would be ALOT easier to tune on SD.
Thanks
Old Mar 14, 2009 | 08:13 PM
ITP's Avatar
ITP
Figured out the problem thanks to a thread posted by Applaudd about a HKS intake. Looks like I will have to redesign the turbo inlet pipe. Maf was hooked up to a 3" pipe with a 3"-4" reduce at the 35r. So I jimmyed a 2.5" pipe and the Hz's dropped back down to about 34hz and the afr's were more stable as well. Not to mention it fixed an off idle tip in issue. So apparently the maf's are sensitive to pressure drop. Time for some fab work.
Old Mar 15, 2009 | 09:12 AM
ITP's Avatar
ITP
I stand corrected on my own post. It was a 3.5" pipe going from the maf to a 3.5-4 reducer at the turbo.
Old Mar 15, 2009 | 07:32 PM
Appauldd's Avatar
WOO HOO....I am glad I was able to help.
Yeah the MAF does not like the pressure drop created by larger hard intake pipes. The Hz needs to be stable to affect idle.
Paul
c08
Mar 21, 2017 03:15 PM
ValdezeEvo
Apr 15, 2010 02:36 AM
l2r99gst
Feb 24, 2010 07:04 PM
PDXEvo
Aug 11, 2005 10:43 AM
