wb o2 help
Old Mar 24, 2009 | 09:16 PM
v-manracing's Avatar
wb o2 help
I'm using the 94170015 tephra v5 mod with o2 simulator, I have a Lc-1 hooked the brown anolog wire to pin 75 to try to log afr.
now I got a cel and I don't know if mitsulogger works with it cause all I see in rear o2 is volts. can you use mitsulogger or will I need evoscan? Or do I need to add 8409 to the MUT 12 table like stated in" logging without serial cable thread" ? also where at mut 12? 0, 1, 2....etc
