how do you activate the Tephra mods?
Old Mar 30, 2009 | 08:45 PM
T_Jochum24's Avatar
So i've got the tephra mod 85590015 today but i can't seem to figure out how to activate the rear 02 sim patch on the tephra mod.. Any help would be much appreciated.
Old Mar 30, 2009 | 09:29 PM
rolly1818's Avatar
Registered User
look in ecuflash under the mods section. the first one should say Tephra's mod it should be in there once you set up the rom correctly.
Old Mar 30, 2009 | 09:33 PM
T_Jochum24's Avatar
it is there, but there is only a box next to all the tephra mods that u can only enter a value into?..
Old Mar 30, 2009 | 09:51 PM
rolly1818's Avatar
Registered User
no its a LONG list lol
the first one is where you put in 0s or 1s even 2s to activate or deactivate the corresponding mods.
the rest are the parameters in which the mod works by. NLTS TPS, ALT Map WGDC, etc.
Old Mar 30, 2009 | 09:57 PM
T_Jochum24's Avatar
does the value "0" activate the mod?
Old Mar 30, 2009 | 09:59 PM
rolly1818's Avatar
Registered User
nope 1 does, i am not on my ecuflash pc lol
i can post up some pics tomorrow to assist?
Old Mar 30, 2009 | 10:05 PM
T_Jochum24's Avatar
yeah, thad be more than great.. getting tired of this CEL always being on. I got the rear o2 heater patch to work correctly but this one is being a lil stubborn.
Old Mar 30, 2009 | 10:42 PM
v-manracing's Avatar
when I did mine I got a CEL also, I tried unpluging the neg on the battery and it got rid of it
Old Mar 31, 2009 | 06:09 AM
rolly1818's Avatar
Registered User
hope this helps:
Old Mar 31, 2009 | 06:52 AM
cij911's Avatar
Do you know where there is detailed information on each of the modification (i.e. Valet) and how it works? I really would love to use the knock/ boost cut feature and Valet feature, but would like to know more about them before I select a '1' lol.
Scenario -- I drive up to a nice restaurant with the Mrs. and have to Valet the car, how do I activate Valet? When I am done with dinner and ready to drive home, how do I turn off Valet mode?
Old Mar 31, 2009 | 06:55 AM
T_Jochum24's Avatar
thanks for the pics.. it still being funny tho, when i go to activate any of the mods, they still will not turn on.
Old Mar 31, 2009 | 08:12 AM
rolly1818's Avatar
Registered User
some of my mods are giving some trouble as well.
post some pics and some fo the experts will get in to help.
Old Mar 31, 2009 | 09:00 AM
rolly1818's Avatar
Registered User
detailed information is right there in Ecuflash under the mods section. the one i selected just shows on/off.
look in ecuflash on the side under the mods section of your rom you should see:
Valet Rev Limit
Valet Rev Limit Time to Activate
Valet Rev Limit Flash Time
i believe (correct me if wrong) the mod once turned on (selecting one in the main tephra window) is activated/de-activated via pressing the gas pedal fully when the car in on (not started).
Old Apr 1, 2009 | 12:21 PM
PessimiStick's Avatar
Valet Rev Limit
I'm not 100% sure how normal Valet mode works without checking the thread since I use Auto-Valet on Fresh Ignition, but to toggle it you turn the key to the "On" position with the car off, and hold the throttle for [Valet Rev Limit Time to Activate] time.
With auto-valet, the car defaults to Valet mode, so when you just get in and start the car, it will be using the Valet Rev Limit. I have mine set on 250 RPM so the car won't start at all if you don't switch to normal mode.
Old Apr 1, 2009 | 12:38 PM
rolly1818's Avatar
Registered User
nice so basically its ur "Tephra-made" immobilser
