PTE 880cc Scaling help
Old Apr 27, 2009 | 05:05 AM
  #31
Drill_Sergeant's Avatar
Veteran: Army
Originally Posted by voidhawk
are you using EvoScan or MitsuLogger to check trims? EvoScan doesn't work right for fuel trims so you should use Mitsulogger ... just a thought.
i'll use mitsulogger when i get out of work today. is it really that different?
Old Apr 27, 2009 | 05:55 AM
  #32
gsrboi80's Avatar
812
3.312
1.68
1.344
0.96
0.744
0.456
0.24
Old Apr 27, 2009 | 06:31 AM
  #33
SEEnoEVO's Avatar
Why do you say this?
As long as it is a more recent version, I would think he would be fine. Wasnt the code updated?
Old Apr 27, 2009 | 06:53 AM
  #34
voidhawk's Avatar
I was also wondering how to set/un-set the cold start timing retard function? I've found people talking about it by searching, but not how to actually switch it on/off and it might help my idle problem. Thanks!
Old Apr 27, 2009 | 09:56 AM
  #35
RoadSpike's Avatar
Its Ecu Periphery FAA Bit 9, disable it by setting it to 0.
See this chart:
https://www.evolutionm.net/forums/at...t_20080830.pdf
Old Apr 27, 2009 | 09:57 AM
  #36
RoadSpike's Avatar
Originally Posted by wip
Hi, would you tell me the numbers you used please? As I've read the thread you mentioned and tried allsorts, still no joy
Cheers.
I'll get them when i get home i don't have my laptop on me.
What rom are you using? My tables could be a different version.
Old Apr 27, 2009 | 01:00 PM
  #37
wip's Avatar
wip
I'm on 88570008.
I think I'm meant to be changing this:
(This is the standard rom)
I've tried upping the fuel in the 20, 34 and 50 columns, but it doesn't seem to make any difference.
Old Apr 27, 2009 | 01:22 PM
  #38
RoadSpike's Avatar
I'm on 88570008.
I found it was dumping in too much fuel honestly I remember pretty well having to reduce the higher values.
From the stock table I multiplied the table from 50 down by .684 which is the number of scaled cc's/ stock cc (750 for me / 512 stock).
Old Apr 27, 2009 | 01:34 PM
  #39
wip's Avatar
wip
Ah, I'll try reducing the fuel then
I suppose it makes more sense than what i was thinking
It is just the cranking primer (or equivalent on your rom, is it the IPW adder?) that I'm changing isn't it?
Cheers.
Old Apr 27, 2009 | 01:43 PM
  #40
RoadSpike's Avatar
Cheers.
In my rom i'm fairly certain its labled as "IPW Adder" however if thats correct or not is certainly up for debate . I had to scrounge around to find the rom address myself for the 96240008 romid which isn't included in the thread
Old Apr 27, 2009 | 01:46 PM
  #41
wip's Avatar
wip
I'll plug the new numbers in and give them a try tomorrow, fingers crossed this will be one thing to tick off my list of 'things that annoy me', next has gotta be 'squeeling brakes'
Cheers for the info, I'll report back when I've tried it
Old Apr 27, 2009 | 10:57 PM
  #42
RoadSpike's Avatar
OK the values for my table "water temp enrichment"
Temp - Units
-32 = 108
-18 = 90
-8 = 65
7 = 49
20 = 31
34 = 14
50 = 8
77 = 8
82 = 8
Old Apr 30, 2009 | 10:13 PM
  #43
Veteran: Army
wow i fixed my problem...
went back to stock MAF
the MAF-T and GM MAF setup is garbage.
Fast_Freddie
Oct 30, 2023 01:56 AM
superkizuna
21
Nov 5, 2016 07:11 AM
jhoganusaf
Jan 24, 2014 06:03 PM
ApacheToYaDome
Jun 6, 2013 04:48 AM
mrfred
Apr 21, 2013 09:37 PM
