Noob needs help!
Old May 7, 2009 | 02:19 PM
wtf_is_a_evo's Avatar
Noob needs help!
Ok i got a lot of questions on logging/tuning.
First off i have read How To Tune your evo (over and over) and i under stand most of it, ok first evoscan im useing 2.6beta11 i have openport2.0 usb i have aem wideband with wire hook up and serial to usb adapter ran it to my laptop went to the top selected com port that its ran to and put it on aem wideband. Now here is where im confused do i check mark the External wideband A/f ratio or WB02? And maybe i missed something else but thats ill i have to do to log my a/fs right?
Next thing is a tuning question im running real low 10 right when boost hits(22.5psi) (i wanna say b4 3,000rpms) and it leans out to 12 right after that. I know 12s are to high for pump gas so i need to make it richer, But on my logs i hit peak load at 3687.5 rpms with timing advance at 6, a/f is 12s my load is only at 222.925 (im useing load calc) Besides the a/fs does that sound right?
I took a print screen of the log.
If you need more info to help me out let me know.
I will take any advice thanx
p.s more questions to come im sure
Old May 7, 2009 | 03:30 PM
rolly1818's Avatar
Registered User
load sounds normal , get the AFRs to 11.5 or thereabouts.
any knock? ur log is not coming up on my screen sorry.
Old May 7, 2009 | 04:35 PM
1 out of 3 logs i get 1 count of knock.
