EvoScan stops logging AFR?
I have an Innovate LM-1 (serial port connection) and evoscan 2.5. When I'm logging AFR and lift the throttle, the AFR goes up (as it should), but at some point evoscan stops logging it and I have to stop and start evoscan again. Anyone else have this problem or know the solution? Thanks for the help in advance.
Innovate products are picky about Ground also I would check that.
Random thoughts is all Good Luck
