Best ECUflash version
Old May 16, 2009 | 10:53 AM
bchappy's Avatar
Hey everyone I am on version 1.29 for its reliability.
I am also using a old tactrix cable.
What version should I step up to? I am tired of switching ROM XML files and modding them everytime a friend wants something fixed or checked on their cars.
Thank you for any help!
Old May 16, 2009 | 04:45 PM
bchappy's Avatar
30 views?
thanks for the help!
I just want to know if the new versions are stable and reliable.
Old May 16, 2009 | 06:02 PM
G20's Avatar
G20
the latest version from openecu.org works just fine for me. I'm using the old cable as well.
Old May 16, 2009 | 06:07 PM
Deepnine's Avatar
lastes Version works good. Never had any problemes since 1.29.
Old May 16, 2009 | 06:17 PM
GotWheelHop's Avatar
The later versions also give you access to the ECU Periphery tables, B.
You can't utilize them on older versions if I remember rightly.
Old May 16, 2009 | 06:58 PM
nothere's Avatar
yeah 1.41 is really worth it.
Old May 16, 2009 | 08:56 PM
Kracka's Avatar
v1.40 is working really well for me. Does v1.41 add any extra features for us non-X guys?
Old May 16, 2009 | 09:07 PM
Lvis's Avatar
how is ecuflash for dd's and weather changes? does it adjust itself? i heard some ecu flashes dont
Old May 17, 2009 | 12:12 AM
Mattjin's Avatar
I found that if you have the Limitless cable (v1.3U is what I have) that it refuses to work with anything newer than v1.34, but that version works rock solid for me.
I have a second laptop I use with the OP2.0 cable and with it ecuflash v1.41 works without any issues at all.
Old May 17, 2009 | 12:20 PM
rolly1818's Avatar
Registered User
i found that if you have the limitless cable (v1.3u is what i have) that it refuses to work with anything newer than v1.34, but that version works rock solid for me.
x2
Old May 17, 2009 | 12:36 PM
I have a version 1.3 cable, but I got it from Colby.....is the Limitless cable any different?
Old May 17, 2009 | 05:03 PM
Roni-Wan's Avatar
so 1.3u cable won´t work with the newer ecuflash version?
Old May 17, 2009 | 07:26 PM
Kracka's Avatar
Works fine if you set it up properly. Search around, plenty of threads pertaining to the matter.
Old May 17, 2009 | 07:27 PM
Kracka's Avatar
ECUFlash just reflashes the stock ECU with adjusments. The stock learning parameters are not disabled so it really comes down to your tuner giving you a good tune.
Old May 18, 2009 | 08:25 AM
fostytou's Avatar
EvoM Community Team
The most recent version. Always.
My 1.3 cables from both tactrix and evoscan both work great.
