Periphery bits - advice required
Old May 22, 2009 | 11:45 PM
rolly1818's Avatar
Registered User
i have a JDM Evo IX but recently changed to rom 88580014 (AUDM rom id).
i have these lines in my evo9base to remove the CELs for rear O2, EGR etc.
<table name="Periphery 4" category="Misc" address="fea" type="1D" level="1" scaling="Hex16"/>
<table name="Periphery 3" category="Misc" address="fda" type="1D" level="1" scaling="Hex16"/>
<table name="Periphery 2" category="Misc" address="fca" type="1D" level="1" scaling="Hex16"/>
<table name="Periphery 1" category="Misc" address="fba" type="1D" level="1" scaling="Hex16"/>
can anyone interpret what this means? i am guessing each represents each of the periphery things. e.g.
^ this turns off the entire FEA Periphery 4 series in the spreadsheet??
i know how the regular periphery bits work in the other format but i keep getting a "no match" error coming up as seen below:
Any help will be greatly appreciated Thanks
Old May 23, 2009 | 06:14 AM
SkyNight's Avatar
Insert this code in your evo9base_X.xml
<scaling name="blobbits" storagetype="bloblist" storagebits="1">
<data name="0" value="00"/>
<data name="1" value="01"/>
</scaling>
Old May 23, 2009 | 09:28 AM
rolly1818's Avatar
Registered User
</scaling>
thats exactly what i have??? still showing up as "no match". i wonder if its because i got ecuflash 1.34?
also, anyone understand how this works:
Old May 23, 2009 | 11:36 AM
fostytou's Avatar
EvoM Community Team
It is absolutely because you have ecuflash 1.34. This has been covered alot of times.
The numbers you are seeing are pointing to the same thing. They are a different (normal) form of displaying the blobbits. A different view if you will. This has been covered quite a bit also. MrFred has posted a spreadsheet to convert blobbits to hex, however your best bet is to upgrade to the newest ecuflash version. You might be able to see your launch control stuff then also.
Old May 23, 2009 | 12:15 PM
raasfaas's Avatar
^yup what he said...v1.35 is as old as you can go to be able to view these periphery bits thru blobbits.
Old May 23, 2009 | 04:20 PM
rolly1818's Avatar
Registered User
u have saved me soo many times on this forum lol.. Thanks.
does anyone have ecuflash 1.35 OR one that does not require XP SP 3?
i cannot update to SP3 here (company laptop).
Old May 24, 2009 | 10:46 AM
rolly1818's Avatar
Registered User
bump for 1.35
Old May 24, 2009 | 12:04 PM
raasfaas's Avatar
Here you go bro:
http://openecu.org/downloads/
Old May 24, 2009 | 02:04 PM
rolly1818's Avatar
Registered User
^^ thanks!
tephra
Oct 18, 2025 06:25 AM
tephra
Dec 17, 2024 01:36 PM
senate6268
Lancer Engine Management / Tuning Forums
272
Jun 25, 2024 08:27 AM
tephra
57
Dec 23, 2023 09:14 AM
tephra
Aug 29, 2021 04:47 AM
