Engine Trouble Code Cycle Time?
Old May 31, 2009 | 06:48 PM
Creamo3's Avatar
How long does it take or how many miles for the ECU to cycle through all the trouble codes? The reason I ask is that I want to take my car to get emissions tested, but I have been resetting the ECU lately to clear my fuel trims to get my injectors scaled in. I have put ~100 miles on the car since the last time I pulled the negative to the battery. Anyone know if this is enough miles or should I put some more on the car before getting my OBDII scanned?
Old May 31, 2009 | 06:51 PM
FedEvo8's Avatar
Usually it's about 70 miles...You should be okay.
Old Jun 1, 2009 | 02:46 PM
inco9nito99's Avatar
No definite mileage as far as I've seen.
Old Jun 1, 2009 | 03:30 PM
fostytou's Avatar
EvoM Community Team
I don't believe its miles, I think its more along the lines of a certain amount of time or "cycles" in the specific area that needs to be checked to initiate a "ready"
Note: we can now set monitors to ready and passed
Old Jun 1, 2009 | 06:26 PM
Creamo3's Avatar
Do tell , I have disabled the Evap/EGR stuff via the periphery bits, same w/ the rear O2 sensor. Hopefully you can point me in the right direction, I'll try searching in the meantime.
Edit: Found the thread and applied Acumus patches, looks like all systems are go. I even checked it out w/ my buddies OBDII scanner and all tests were ready and passed. I love these disassemblers
Old Jun 1, 2009 | 06:28 PM
Creamo3's Avatar
I had about 130 miles on the car when I went to get tested today, unfortunately not all sensors were in a ready state. I'll have to look into tricking the ECU into thinking everything is good as mentioned above.
