Idle tuning - question/advice
Old Oct 6, 2009 | 01:45 PM
  #46
hydra's Avatar
Originally Posted by Appauldd
The Idle stability control is this.....
<table name="Idle Stability Timing Control" category="Timing" address="174e" type="2D" level="2" scaling="uint16">
<table name="Settings" type="Static X Axis" elements="3">
<data>Sensitivity</data>
<data>Timing Limit</data>
<data>Untested</data>
</table>
</table>
Add this to your 94170015 xml. It will allow you to increase the sensitivity for idle. Helps to keep the car from hunting at idle. Stock value is 128....raise it to about 146.
Second question....I didn't mean raise the Hz values, I meant raise the scaling values. Sorry about that.
Third question.....Yes you should start to see some LTFT adjustments.
What would be the odds of anybody having the correct addresses for 90550001? Thanks!
Old Oct 11, 2009 | 08:39 AM
  #47
hydra's Avatar
anyone?
edsct9a
Jul 26, 2016 01:41 PM
9!'clipseDOHC
Jan 9, 2016 10:21 PM
Appauldd
Jan 8, 2010 06:37 PM
