Error message with Ecuflash
Old Jun 23, 2009 | 03:43 PM
GBAILEY472's Avatar
Anybody know what this means ? system won't load my ECU What do I do.. I need a tune
[18:33:46.601] EcuFlash Version 1.41.2483
[18:33:46.601] OS Version Windows Vista
[18:33:46.601] Qt Version 4.4.0
[18:33:46.611] 26 memory models read.
[18:33:46.611] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[18:33:46.802] 342 ROM metadata models scanned.
[18:33:46.802] checksum module "subarudbw" loaded.
[18:33:46.802] checksum module "mitsucan" loaded.
[18:33:46.802] flashing tool "wrx02" loaded.
[18:33:46.802] flashing tool "wrx04" loaded.
[18:33:46.802] flashing tool "sti04" loaded.
[18:33:46.803] flashing tool "sti05" loaded.
[18:33:46.803] flashing tool "mitsukernel" loaded.
[18:33:46.803] flashing tool "mitsukernelocp" loaded.
[18:33:46.803] flashing tool "mitsubootloader" loaded.
[18:33:46.803] flashing tool "shbootmode" loaded.
[18:33:46.804] flashing tool "shaudmode" loaded.
[18:33:46.804] flashing tool "subarucan" loaded.
[18:33:46.805] flashing tool "mitsucan" loaded.
[18:34:18.459] J2534 API Version: 04.04
[18:34:18.459] J2534 DLL Version: 0.50.2464 Jan 29 2009 10:58:58
[18:34:18.459] Device Firmware Version: 1.05.2463
[18:34:21.221] sending init sequence 1 (0001)
[18:34:24.498] sending init sequence 1 (0003)
[18:34:27.773] sending init sequence 1 (FFFF)
[18:34:30.487] no response to any known code
[18:34:30.487] interface close
Old Jun 23, 2009 | 03:52 PM
ethan169's Avatar
hmmm i havent seen that before.
But did you try uninstalling ECUFlash and installing the latest version? Make sure when installing it also installs the OpenPort 1.3 software (should do this automatically)
Hope this helps
-ethan
Old Jun 23, 2009 | 05:49 PM
GBAILEY472's Avatar
I read some more and found that i might be locked out. so I downloaded Ecuunlocker.. but I dont think it works with Vista, is it possible cause it wants to open as a .rar file ? Anyone ?
Old Jun 23, 2009 | 10:59 PM
codgi's Avatar
You're running 64 Bit Vista correct? So what error does it give after you download the Ecu Unlocker?
Old Jun 24, 2009 | 08:10 AM
GBAILEY472's Avatar
OK.. downloaded winrar. and downloaded Active Matrix ecu unlocker.... Everything works...
Thread closed !!
Old Jun 24, 2009 | 08:25 AM
travman's Avatar
ecu unlocker works fine with vista 64-bit - glad you got it figured out.
MR Turco
Jul 2, 2025 05:30 PM
lonestarevo83
Jul 15, 2011 07:20 PM
sweeney87
Apr 9, 2011 02:26 PM
waskarn
Lancer Engine Management / Tuning Forums
Jul 23, 2010 08:04 PM
Srt4...
Mar 23, 2010 10:05 AM
