FP Green, FPR4 cams, Meth, And TBE Tune
Old Jul 6, 2009 | 01:44 PM
EVOIXreno's Avatar
Here it is... let me know what you think, boost is 30psi tapering to 26-27 by 7400.
AFR is 12.0- 11.9 down to 11.7-11.6.
The before on the dyno was a with a cracked megan manifold(didn't find out till later) and a m5 meth nozzle 2 occupants.
The after is stock manifold and a m7 nozzle. 3 occupants
Cory
Attached Thumbnails FP Green, FPR4 cams, Meth, And TBE Tune-alex-map.jpg   FP Green, FPR4 cams, Meth, And TBE Tune-alex-dyno.jpg
Old Jul 6, 2009 | 01:50 PM
diiirk@AwdMotorsports's Avatar
are you getting any knock counts up top? on meth you should be able to get away with a little more timing than that. Or does 91+meth not allow that?
Old Jul 6, 2009 | 01:54 PM
EVOIXreno's Avatar
Yea if I add any more timing i get 4-5 counts! it sucks
Old Jul 6, 2009 | 04:15 PM
LostSolVTEC's Avatar
kinda curious about this, but why is the first pull the driver weight is at 450lbs and the second it's at 630lbs?
If you really do weigh that much I apologize in advance I'm not trying to pick on it, just wondering if that has anything to do with the difference in numbers. Unless there was more than one occupant which would make sense.
Old Jul 6, 2009 | 04:18 PM
Jack_of_Trades's Avatar
The top end might be suffering from the elevation he is at.
Old Jul 6, 2009 | 04:20 PM
EVOIXreno's Avatar
Doesn't hurt to read... JK it's kinda hard to spot
Old Jul 6, 2009 | 04:23 PM
EVOIXreno's Avatar
from what I have experienced is that at this altitude I can't hold power at all with these boost levels.. I have tuned a couple others at sea level and they hold fine... Stupid altitude!!!
Old Jul 6, 2009 | 07:11 PM
lol I'm not into meth injection, when I read that I thought that was the number or nozzles or something
Old Jul 6, 2009 | 08:40 PM
Appauldd's Avatar
Get rid of the Megan Manifold....go with a ported stocker.
Some things I did to help my Green was to...
Port the head
Port the ex mani
Port the hot side
Port the 02 (kills boost creep)
Wrap the exhaust past 1/2 of the car (keeps the heat in the exhaust for faster flow)
Can the MBC....use the stock boosc control or get an EBC (will nearly kill boost taper)
Replace the throttle body seals (stock leak like hell)
The green needs to breathe to really release it's power. Port, port, and port some more....you will be amazed at the few mm's of material removed will greatly enhance your power.
When does your Meth start to spray?
Good numbers though.....Great Job ! !
Old Jul 6, 2009 | 11:17 PM
EVOIXreno's Avatar
Port the head
Port the ex mani
Port the hot side
Its a customers car I am doing the porting on my car... I told him to do the ported stuff but his budget can't help to much!... I believe it starts at 9-11 psi..
Thanks I thought the #'s were pretty decent!
Cory
Old Jul 7, 2009 | 05:11 AM
Careful wrapping your exhaust below the car. It traps water in the heatwrap and will kill your pipes in no time if you don't daily drive it.
Old Jul 7, 2009 | 05:23 AM
~BoOsTeR~'s Avatar
Forgive my ignorance, I haven't been frequenting the Tuning section lately, but what is the EvoM virtual dyno?
lol ^ that's where just waking up gets you rofl.
Old Jul 7, 2009 | 05:33 AM
Appauldd's Avatar
I use the high temp sealant and my car is driven daily....no issues with wrapped exhaust since 2003.
Old Jul 7, 2009 | 06:16 AM
Yeah, its not much of a problem if driven daily. I figured I'd add the disclaimer since a lot of guys have a separate daily driver these days
Old Jul 7, 2009 | 09:40 AM
Appauldd's Avatar
Thanks for the clarification. I forget some times that many people don't drive their Evo every day like I do.
