EvoScan 2.5 and LC-1 skipping?
Old Jul 9, 2009 | 01:34 AM
ohhgyeahfasho's Avatar
Hey guys, I am having problems whenever I log my LC-1 wideband via EvoScan 2.5. Whenever I log the wideband, the wideband readout would skip around some cells if I am logging only a few parameters. I am using a Sewell Direct usb to serial adapter. I just want to know if anyone is having the same issue I am having and if it's normal to see the wideband readout skip.
for example: (i made up these numbers)
RPM WideBandAF
3218.75 12.2157
3281.25 11.9364
3343.75
3406.25 11.8482
3437.5 11.8188
3531.25
3531.25 11.6865
3656.25 11.6571
3687.5
3781.25
3906.25 11.4954
3968.75
4093.75 12.1863
Old Jul 9, 2009 | 02:09 AM
leecavturbo's Avatar
log more items
Old Jul 9, 2009 | 02:10 AM
i do have a macro for excel to fill in the gaps based on the average of cells above and below the missing cells. looks correct in a graph unless you have big gaps.
Sub FillEmpty()
Application.ScreenUpdating = False
Application.Calculation = xlManual
Dim cell As Range
For Each cell In Intersect(Selection, _
ActiveSheet.UsedRange)
If Trim(cell) = "" And cell.Row > 1 Then
cell.NumberFormat = cell.Offset(-1, 0).NumberFormat
cell.Value = ((cell.Offset(-1, 0).Value + cell.Offset(1, 0).Value) / 2)
End If
Next cell
Application.Calculation = xlAutomatic 'xlCalculationAutomatic
End Sub
Old Jul 9, 2009 | 05:47 AM
chmodlf's Avatar
Readout skip is normal. I get it too. You can attach the LC-1 to the ecu. From what I remember there are no skips.
https://www.evolutionm.net/forums/ec...ial-cable.html
Old Jul 9, 2009 | 05:52 AM
logic's Avatar
What chmodlf said. The LC-1's serial data rate (at least, as implemented with EvoScan) is abysmally slow. Logging via the ECU results in a much more reliable result.
Old Jul 9, 2009 | 10:12 AM
Sub FillEmpty()
Dim cell As Range
End If
Next cell
End Sub
Ok, let me try this out. Now, all I need to do is look up how to make a macro on excel. :P
damn, i really didn't want to go that route but if it will give me better results I guess I better suck it up and do it then. Anyways, thanks for your help guys.
Old Jul 9, 2009 | 12:11 PM
jrohner's Avatar
Just ignore the spaces and approximate in your head what the AFR is, or log a couple more items. I always log around 10 items (plus the calculated stuff) and there are no gaps, yet the logging resolution is still quite good.
Old Jul 9, 2009 | 08:34 PM
silver_evo's Avatar
Haha! I made a program for this a long time ago. Funny to see old problems pop up again. I use logworks3 now, but here ya go!
https://www.evolutionm.net/forums/ec...log-fixer.html
