Map Switching In Evo X While Using Aquamist? Tephra?
I had an Aquamist HFS-1 in my IX and loved it...stock turbo, spooled amazing, tons of power. I want to add an Aquamist kit to my X but i told myself its too early as the car is still new at only 2-3 months old. I was debating on doing cams and the FP Red first, or cams and and Aquamist first. I would like to see what the stock turbo can do so im wanting to do MX1 cams and an Aquamist kit....only if i am capable of using map switching to turn meth kit on/off and swtich between meth map/pump map. Example on the older Evo's here (this is what im looking to do): https://www.evolutionm.net/forums/wa...ther-last.html
So the main question is did Tephra come out with this yet for the X's? If not when is it going to be out? Or is there another way i can make this work?
I am fairly new to this. When i had my IX i did do online flashes at one point so i do have EcuFlash. I found a thread where it explains how to load up Tephra patches and it seems a bit confusing but if anyone could give me some info on it that would be great. Would i need anything else other than the Tepthra patch? Is that all that is needed to be able to switch between 2 maps and turn meth on/off?
nobody knows anything about this???
is Tephra planning on coming out with this? or any other way this could be done?
i bet theres alot of people who would like this on there X.
its in progress.
Aquamist are sending me a HFS6 so I will be able to get map switching and stuff going soonish..
I would say it would be a couple of months away at least...
its in progress.
