EVOSCAN XML help plueeease...
I have searched and found topics covering the xml changes that need to be made in EVOSCAN .99, but I am utilizing EVOSCAN 2.5 version...
I have recently upgraded from the stock boost control over to a 3 port solenoid, 4 bar map sensor, and 18 WGA.
Question is, do i need to make any adjustments to get boost logging to work?
I will be installing the AEM UEGO and the Boost Guage here in the next week, as well as some go fast parts. I am trying to do some preliminary logs now to get some info, and then run some again, after the upgrades next week.
If any one could chime in and let me know. I did find an updated xml for the version .99 in the ECUFlash stickys. Top sticky I beleive, but am not sure what has been fixed in this new version, and what I need to do...
It all depends on what map sensor you are using..
