ROM 88840017 - JDM MAP and TE 2J1 WB
than search for bosch harness
I think it will work without a problem.
It`s hard to find it but if you will search it maybe you can see if it will fit or not.
This is what I remember about JDM 3bar map about this bosch connector.Maybe they have also the socket how knows.
I think you are the first one who did this or maybe we don`t know where to look.
I think that many car's use Bosch - I have found the above number in a manual for an Fiat/Seat and I plan to visit the junkyard to open hoots and search
I have found that Bosch have the part in stock, byt they cant provide any data sheeds
Give me some more time to finde a sloution.
.I have found that Bosch have the part in stock, byt they cant provide any data sheeds
To day I did finde a connector that fits so I will install this weekend.
And have also found this Bosch Part No. ( photo album updated )
Bosch •1284485112 shuold be the connector.
Bosch •1280703022 shuold be the plastic cover ( water protection ).
Bosch •1987352119 shuold be the pins.
I will try to make an order of this part No so I can confirm them later on.
Ordred form Germany Auto-Bendig GmbH
Ok Google
I did find a spot where to download the Wiring diagrams for USDM Evo IX
USDM Sensor Connector name is: B-135
EDM ECU Connector name is: C-117, C-119, C-121
Sensor: ECU:
Pin 1 Pin 92
Pin 2 Pin 49
Pin 3 Pin 42
Thanks to the spot where I finde the manual
Sensor: ECU:
Pin 1 Pin 92
Pin 2 Pin 49
Pin 3 Pin 42
It is made from the 3 part no. from #18 - The B-135 notation is from Mitsubishi manual for an USDM Evo IX and as you know our EDM Evo IX do not have the MAP sensor nor the wiring from ECU to MAP sensor.
Dont worry I will make a "how to" write up in #1 when all test are don.
