ECU Control Boost and Tephra Mod
Old Aug 24, 2009 | 10:31 AM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
So with my recent upgrade to the FP red I would like to use ECU Controlled boost. Now I know everyone is using the GM 3 port Boost Soleniod. I was going to buy one from Tactrix or Gruppe-S. My question is how well are they at holding boost.....as of now with my EBC I only loose 1.5psi from peak boost to redline? I know I have to get a map sensor so I think I'm going with the Omni 4 bar to log boost but right now I'm very confused with all these mods and add ons for ECU flash.
Tephra Mod I would like to run ver 5-6. I know ver 5 has the alt map and switch and I would like to run that switch with Meth and then ver 6 for boost controlling. Is this a easy upgrade?
Old Aug 24, 2009 | 10:49 AM
GST Motorsports's Avatar
You can use Ecu-boost without any tephra mods, if you want map switching, V5 works solid with ecu boost control
I'll let the man answer the V6 question
Old Aug 24, 2009 | 11:02 AM
DBallz's Avatar
How well does the 3 port hold boost? If I was to run 25 psi in 4th would I taper more then i do now?
I like some of the feature of V6 but I see it's still in the testing phase
Old Aug 24, 2009 | 11:35 AM
With a Red you should hold 25psi no problem straight across.
I've had a red hold 30psi straight to cutoff on a 05 Evo with a 3port:
Old Aug 24, 2009 | 06:15 PM
DBallz's Avatar
Great thanks for the info. I plan on running 27psi on pump as I am now and then alt map with meth @ 30-35 psi. Now we just have to get Tephra to launch Ver 7
Evo_Goodness
Aug 30, 2016 04:00 AM
tscompusa
Feb 26, 2016 03:22 PM
hearnoevo
Dec 11, 2014 09:42 AM
The442GTO
33
Nov 9, 2009 02:37 PM
whiteEv0boy
Jun 7, 2005 07:07 AM
