96530006 SD issue?
Old Aug 27, 2009 | 09:48 AM
JohnBradley's Avatar
96530006 SD issue?
Okay so I have been searching trying to figure out why when I do a NLTS SD version of this ROM it doesnt want to start. I am using a 5.1 based ROM but I cant seem to figure out what I am missing. Absolutely no problem with the base SD ROM, I just cant figure out what I am missing. A link perhaps to the proper info so I can read...I dont like having an answer just handed to me. More fun when I have to work for it.
Thanks guys
Aaron
Old Aug 27, 2009 | 11:34 AM
l2r99gst's Avatar
I have had SD running on many versions of the 96530006 Tephramods ROMs. V5.1, V7t6, etc. I never had any problem with the car not starting.
I would venture to guess that maybe the valet limit is enabled. Try disabling that or set it to a higher value. And of course, the immobilizer trick, just in case you are using a fresh ROM and didn't update that.
Eric
Old Aug 27, 2009 | 11:58 AM
Eric
Thanks Eric. I didnt even think about the valet mode causing an issue. It started off at 114 so I altered it to 3500 like I normally do, but it cranks, almost starts and nothing. Immobiliser should be off...I hope I didnt forget that one. I am going to double check and make sure I wasnt trying to use V5 or something and maybe have a conflict somewhere like that.
aaron
