stock mas limit finally found?
Old Aug 31, 2009 | 08:44 PM
  #31
Appauldd's Avatar
Originally Posted by Mellon Tuning
nothing major it just lowered the load a little.
What do you mean "lowered the load"? There isn't such an animal in the MAF tables. Please explain.
Old Aug 31, 2009 | 10:15 PM
  #32
GST Motorsports's Avatar
He means when he took the honeycomb out, that the measured load lowered.
EXAMPLE: He was logging 380 peak load before with the honeycomb in, and he took the honeycomb out and everything else the same, the logged peak load dropped to 360.
On Topic:
I'm ramping up to do a stock ECU SD conversation on a significant build here pretty soon so I will most likely be needing some help from some people in this thread shortly.
Old Aug 31, 2009 | 10:24 PM
  #33
RoadSpike's Avatar
On Topic:
You want to do a 3,4,5, or 7 bar sensor build?
Old Aug 31, 2009 | 11:04 PM
  #34
Lucas English's Avatar
4 minimum, the 3 is a waste unless you already own it for logging boost. Bryan, dont be afraid to call Aaron at the shop.
Old Aug 31, 2009 | 11:16 PM
  #35
4 bar will be enough, on a Evo 9 I'm curious if anyone is actually doing a 5 or 7 bar that is really using it? ahha
Thanks!
Much appreciated.
Old Aug 31, 2009 | 11:21 PM
  #36
RoadSpike's Avatar
Thanks!
Much appreciated.
5 bar here but...
I'm running it only to 30 psi since i got a stock motor it should be enough data to setup the limit of the sensor with that amount of boost. Sensor is linear so most of the data points that need adjustment are in the lower range where the highest VE gradients are.
Adjustments are very easy if you think the load isn't high enough because you need more fuel you just set the load higher for the boost level. Pretty straightforward.
You are also welcome to the rom I've setup for the 5 bar sensor.
Old Aug 31, 2009 | 11:23 PM
  #37
Hey Roadspike, it's been killing me, do I actually know you away from evom?
Old Aug 31, 2009 | 11:37 PM
  #38
RoadSpike's Avatar
Could be you have any church affiliations thats where i'd say i'm best "known" is in the christian community. I'm not really a car scene guy
Edit:
Looking up hayward its seems unlikely we know eachother unless you work for CBSi like i do and happen to have met me in the networking infastruture team move of my own parent company.
Old Aug 31, 2009 | 11:40 PM
  #39
haha nope, I was wondering if you used to post on NCE or currently on Evo Empire?
Old Aug 31, 2009 | 11:43 PM
  #40
RoadSpike's Avatar
Never heard of those places to be honest
I guess my style isn't unique as I had dreamed it was if I have a mistaken identity here
Old Aug 31, 2009 | 11:46 PM
  #41
never heard of Norcalevo?
Only reason I asked is because it says you are in Sac.
Old Aug 31, 2009 | 11:49 PM
  #42
RoadSpike's Avatar
Ooh so that's what NCE means yeah I've read the forums but never registered there ever.
Old Aug 31, 2009 | 11:57 PM
  #43
haha ok, just curious, NCE is dead now anywho.
Back to our regularly scheduled programming....
Old Sep 1, 2009 | 12:26 AM
  #44
RoadSpike's Avatar
Thought I'd post some pics so people can see not only my shoddy *** welding skillz but what happened to the engine bay in light of speed density.
Attached Thumbnails stock mas limit finally found?-my-camera-157.jpg   stock mas limit finally found?-my-camera-158.jpg   stock mas limit finally found?-my-camera-159.jpg
Old Sep 1, 2009 | 04:47 AM
  #45
Mellon Racing's Avatar
very cool, looks good.
