Logging problem with Evoscan 2.6
Old Sep 13, 2009 | 06:26 PM
brenner's Avatar
Hello, I am having issues connecting to log. ECUflash works great, and evoscan has no problem reading the ECU, but will not connect to log. No change whether with vista 64 bit or XP (tried two different laptops, same results). Just keeps retrying the connection.
I've tried with and without the external wideband checked (AEM UEGO) and no difference either. No issues recognizing the cables. I'm stumped.
Vehicle is an 05 RS
Bren
Old Sep 14, 2009 | 09:35 AM
brenner's Avatar
update... this problem is not only isolated to v2.6. i just tried with v2.5 and same result. I must be doing something wrong but it just wont connect. EXTREMELY frustrating.
b
Old Sep 14, 2009 | 01:47 PM
ir158's Avatar
im also having the same problem on my evoIV with evo VI ecu.Never had a problem before
Old Oct 4, 2009 | 01:03 PM
sevy2213's Avatar
any updates on this? i am new to tuning but i am having the same problem.
Old Oct 4, 2009 | 01:46 PM
Evo_Jay's Avatar
His problem was he had a modded ROM with a different baud rate.
Try using 62500 as baud rate and see it it works. That was the fix for him.
Old Oct 4, 2009 | 02:13 PM
dhammans's Avatar
Are you getting any error message? I've had similar problems and a re-install of EVOScan always fixed it.
I doubt changing your baud rate will fix it, unless you know your settings in the ECU have been changed.
Old Oct 4, 2009 | 02:56 PM
sevy2213's Avatar
i dont know if my settings have been changed. i would doubt but i did have my tuned by a tuner and ecuflash works well but just cant get the loggin to work correctly in evoscan.
Old Jan 26, 2010 | 03:35 PM
Kaizer's Avatar
Hey all, did not want to start a new thread and I have been searching and reading for the last two days....
The issue I am having with Evoscan is I try to log, but the log stops suddenly. I tried a total of 5 3rd gear pulls, 3 of which when stopped, gave me an "empty file". The other two logs stop at 3.5K RPMS.
I did a few low rpm logs a few days ago with no problems.
Any help will be greatly appreciated!!
Old Jan 26, 2010 | 05:21 PM
Drill_Sergeant's Avatar
Veteran: Army
^^^^ what version of evoscan and OS are you using? and what wideband if any?
Old Jan 27, 2010 | 05:11 AM
Kaizer's Avatar
It's the V2.6...
OS is Windows XP...
No, no wideband...
I have tried reinstalling the software with no luck..Just affraid I might hurt the engine trying to get a decent log....
All the settings were left as is, no changes done. Just installed, checked everything except the wideband, and started/tried logging....
I keep reading about baud rate and other things but have no clue what they mean....still a newbie at this...
Old Jan 27, 2010 | 07:11 AM
Veteran: Army
i had an extremely difficult time with evoscan about a month ago. all the uninstalls and reinstalls did not permanently fix the problem.
however, when i uninstalled evoscan using revo uninstaller, i have had no issues since. you could always try that. just google revo uninstaller.
Old Jan 27, 2010 | 08:24 AM
letMeIn's Avatar
I have the same problem. ECUflash connects without any problems, but Evoscan does not connect. 1 time after reinstalling 2.6, and even installing 2.5, I decided to reinstall .NET framework 3.5 and Evoscan was able to connect again. But then I shutdown my laptop and tried to connect again next day, and I couldn't. hmm . Haven't tried since.
Old Jan 27, 2010 | 12:25 PM
Veteran: Army
try revo uninstaller.
i had super problems with AEM UEGO and evoscan all versions. after i used the uninstaller, everything works wonderfully now.
D1andonlyantman
Jan 22, 2017 10:57 AM
Ev0la
Jan 22, 2017 10:45 AM
Dakota Evo
Jul 25, 2016 05:15 PM
erikm-x
Apr 20, 2014 12:29 AM
Werd
Jul 19, 2009 12:38 AM
