Openport 1.3 Unversal
Old Sep 20, 2009 | 01:42 PM
SWOLN's Avatar
It seems I'm having an issue when I connect the Tactrix cable. I've never had it before. My computer says there is new hardware found and tries to load the information for the cable. It doesn't need it because if I cancel it enough times I can log through Evoscan. When I try to just go ahead and install the hardware, it says it can't. Am I missing something? I've uninstalled and reinstalled, Evoscan and Ecuflash, no luck. Any clues? Thank You.
Old Sep 20, 2009 | 01:47 PM
warp9's Avatar
This happened to me when I upgraded Ecuflash to a newer version. It was aggrevating so i reinstalled the older version. Obviously not a fix, but im sure someone on here knows more
Old Sep 20, 2009 | 06:54 PM
lan_evo_mr9's Avatar
Install an older version of Ecuflash (anything older than 1.42) including the drivers. I had a driver issue with the newest version of ecuflash. I installed an older version/drivers, then installed the newest version/cancelling the driver install- that worked for me.
Old Sep 20, 2009 | 07:36 PM
SWOLN's Avatar
Ok that seems like some consistancy. I'll try it out. Thank you both.
Old Sep 20, 2009 | 09:52 PM
JRR's Avatar
JRR
i think what it is trying to do is load drivers for an elm327 style of cable. ive had that happen as well trying to get it to work with pcm scan.
josh
Old Sep 21, 2009 | 09:00 AM
rdtech's Avatar
This worked for me. I was on ecuflash 1.35 for the longest time and decided to change to the latest version of 1.42. I had the same problem. When I plug in the tactix cable, it tried to load the drivers for it but couldn't.
I unplugged it and plugged it back in. This time, I pointed it to where the driver was and it worked. If you let it search, it won't work.
I had to force install it and tell it which drivers to use.
Old Sep 23, 2009 | 06:39 PM
SWOLN's Avatar
Do you remember where or what you pointed it too ?
Old Oct 14, 2009 | 12:02 AM
rdtech's Avatar
driver was is ecuflash folder under drivers.
Old Oct 14, 2009 | 10:10 AM
fostytou's Avatar
EvoM Community Team
Go to device manager and show hidden devices, remove all instances of openport and 1.3 (there should be a few)
-RESTART
-preferably you should run the install in the ECUFlash directory (C:\Program Files\OpenECU\EcuFlash\drivers) at this point
-optionally restart (why not?)
-Plug in the cable and let it do the automatic install.
"Run an older version of ECUFlash..."
.... laughable man
