What maps are affected when scaling is changed
Old Sep 23, 2009 | 02:16 AM
Boosted GP's Avatar
Hi All,
Been trying to find info on the forum about what else is affected when you rescale the units in different tables,
I want to rescale the "mivec max vs coolant temp" and the "max wgdc vs coolant temp" and "MAF IAT WGDC Correction" ranges. as we never see such cold temps here and want better use the blocks for more res.
i.e.
current:
temp correction
-10 -10
0 -5
10 -2
15 -1
20 0
25 2
35 5
desired;
temp correction
5 -10
15 -6
25 -2
35 0
45 5
50 10
need to log the actuals to get a correct correction rate, but you get what i am saying
With Mivec i want to change the coolant temp scaling from
from -32, -8, 7, 20, 34, 50, 77, 82
to 40, 45, 50, 55, 60, 65, 77, 82
max WGDC vs Temp
from temp 20, 30, 40, 50, 60, 70, 80, 82
to 60, 70, 75, 80, 85, 90, 95, 105
for better safety up top as I never boost till warm, but on the track (Autocross) the coolant can go over 100 deg C
Mike
