Ecuflash Expert, please help and guide me. Thanks
Hi
Need help from you guys about the steps I have to do and parts I have to buy to make Stock ECU Ecuflash be able to control my mods properly. The mods parts is on the way. I am going to use my evo 8 MR JDM for Weekend Car and sometime for Track day & drag race.
My Evo 8 MR JDM ECU ID:
- internal ID: 96260007
- memory model SH7052
The Main Engine Mods:
- 2.2ltr stroker kit
- Full Race GT35r Twin Scroll turbo kit
- Jun 272 Cams + Valve Spring kit + Jun Cam Gear
- Perrin Fuel Rail
- Skunk Intake + Throttle Body
- P & P Head
- ARP Head Stud
- Injector Dynamics 1000cc
- Greddy Type R Intercooler
- Other Supporting mods
Noob Questions (sorry for my stupid questions):
1. Please help me or point me out what ecuflash mods should I do?
2. What additional parts should I buy to make Stock ECU works?
3. Should I run Speed Density mods? Is it Safe?
4. This JDM EVO 8 MR doesn’t have stationary rev limit (there is menu for it but non functioning), How to make it work as launch control?
5. How to make stock Ecu to have multiple map/map switch?
6. Also the Load map (timing and fuel) only read until 1.6 bar, how to make it read at least to about 2 or 2.1 bar (29-31 psi) and 9000 rpm?
7. I want to use 4 inches Intake Pipe, Which way is better, modify into blow through system or just run Speed Density or any other alternative?
8. If modify with blow through system is better, What MAF sensor I have to buy that can work with Stock ECU and handle the additional flow?
9. Can Stock ECU to be modify to live/real time tune? If so how o do it?
Hopefully someone willing to help me with all of my noobs questions, and yes I was searched but still confuse and want to make sure the right steps I have to take. Thanks in Advance
- Perrin Fuel Rail
- P & P Head
- ARP Head Stud
Pretty much all these questions could have been answered if you would have taken the time to read through the Ecuflash forum.
You are going to have to do a lot of searching and reading my friend...
Read through the linked threads here as a start:
https://www.evolutionm.net/forums/ec...ead-links.html
Good luck and welcome
98autogstspyder
657
Apr 27, 2022 01:48 PM
mrfred
Feb 26, 2022 06:16 PM
payway87
43
Sep 9, 2014 03:50 PM
