Going Lean ???
Old Oct 30, 2009 | 11:29 AM
3gEclipseTurbo's Avatar
Going Lean ???
Im going lean on take off, I have to rev to 3k to take off without bogging out. Also im going lean at low loads when cruising but the i run rich when i try to hold a steady psi while not wot? but if i go wot the afr are good. Idk the only thing i could think of is that its my bov but i ran a boost leak test and its not leaking. So im back to thinking it has to do with my tune. what could cause this?
Old Oct 30, 2009 | 04:23 PM
rolly1818's Avatar
Registered User
can you post your tables and your rom (pictures)?
i cannot help much if i cannot see whats happening.
Old Oct 30, 2009 | 07:00 PM
whats your email ill send the whole ROM
Old Oct 31, 2009 | 06:21 AM
rolly1818's Avatar
Registered User
pm sent
Old Oct 31, 2009 | 08:04 AM
Routybouty's Avatar
Sounds like during closed loop it's lean.
Old Nov 1, 2009 | 07:34 AM
I thought so to so i put it in open loop and same thing.
Old Nov 1, 2009 | 06:04 PM
If my timing was off would it only affect cruise enough to be noticed, as when im accelerating its fine.
mrm95
Nov 7, 2014 01:04 PM
Go_Lancer_Go
Oct 28, 2014 10:08 PM
crckheadjed
28
May 25, 2012 04:04 AM
5LEEPERISAH23I
May 13, 2012 09:48 PM
turizmo01
71
Aug 10, 2009 10:16 PM
