rc 550 votaje latency compensation ecuflash
Old Nov 7, 2009 | 02:45 AM
gsxrmel's Avatar
hi, what is the voltaje latency compensation of a rc 550 pl-8 injectors to use with ecuflash i read the dead time is 180ms but i need the different volaje latency compensation of the injector to mod with ecuflash.
i,m going to flash mi 2g gsx 98 ecu with the op 2.0 and ecuflash
thanks a lot, sorry my english is to bad i.m spanish
bye!!!!!
Old Nov 7, 2009 | 05:51 AM
Kracka's Avatar
I have a better idea, get a set of used Evo injectors and then you'll have all the stock values already in the Evo ECU
Old Nov 7, 2009 | 10:03 AM
todd6027's Avatar
use a set of 560cc evo 5 on injectors ,evos 1 to 4 had 510cc.
Old Nov 8, 2009 | 06:36 AM
gsxrmel's Avatar
the problem is that i have this injectors in my car and is a new item and i would like use this
thanks for the reply
Old Nov 10, 2009 | 10:32 AM
gsxrmel's Avatar
up!!
Old Nov 10, 2009 | 10:55 AM
Ceddy's Avatar
For the RC 550s you would add .180 to each of the seven items in the Latency Table and enter 550 for Injector Size.
That should get you very close.
Old Nov 12, 2009 | 11:56 AM
gsxrmel's Avatar
thanks ceddy do you know what is the stock value of the seven items latency voltaje for a 2g gsx 1998 ecu
thanks a lot
Old Nov 12, 2009 | 02:15 PM
Ceddy's Avatar
Old Nov 13, 2009 | 01:57 AM
gsxrmel's Avatar
THANKS CEDDY FOR YOUR HELP
goofygrin
36
Jun 27, 2017 11:17 AM
curamrdan
Oct 6, 2016 12:07 PM
foxbat
Jun 1, 2016 03:02 AM
scandinavian
Aug 20, 2009 09:39 AM
dan l
Sep 18, 2008 05:21 PM
