Kernel in .RPG files
Old Nov 10, 2009 | 02:29 PM
Ceddy's Avatar
Has anyone played with any of the MUT Flash Tool .RPG files?
I was looking at some of the H8(1998-2000) .RPGs today and found the flash kernel.
The H8s load the kernel to F290 in RAM, and in the .RPG right before the kernel is F290 as a "header".
The ROM image has all the bytes inverted with a 9 byte command string every 1024 bytes.
Anyone know the commands? Has this been looked at before?
Old Nov 10, 2009 | 05:07 PM
MattS00's Avatar
http://www.aktivematrix.com/forum/viewtopic.php?p=4466
This is the only discussion I remember, that even sounds similar to what you are talking about. Also, the last time I checked, the ecu flash log reports that the kernel is loaded to a slightly different address. Also, when you say bytes inverted are you talking about endian?
Old Nov 10, 2009 | 05:48 PM
Ceddy's Avatar
inverted = 255-x
0=255, 1=254, 2=253, etc...
The ROM code is inverted, but the kernel is normal.
All the H8s I've looked at: DSM, Mirage, 3000GT, have the 0xF290 RAM execute thing, even a kernel written from scratch would have to hook in there.
The kernel is about 3k in size, seems to be a lot more code then would be needed.
I wondering if EcuFlash uses the Mitsu kernel or its own.
Nsk
Jul 11, 2020 02:01 AM
BlackHawk_Tsi
Apr 20, 2015 04:25 PM
myparkerbros
Aug 24, 2013 06:34 PM
wreckleford
Lancer Engine Management / Tuning Forums
May 20, 2012 11:35 AM
project_skyline
Apr 8, 2009 11:49 AM
