Mapping with new cams??
Old Nov 22, 2009 | 02:47 AM
HermaN's Avatar
Was on the rollers yesterday, and was happy with the power I made, but wanting more torque, so I have been thinking of a new set of cams.
I have done a little map tweaking on my car already, but using the Rallart map as my base map.
When fitting new cams and mapping to suit, is it just the same as mapping normally, or is there anything else I should check?
Normally when mapping a stock engine it's usually knock & AFR to look out for (along with logging other things), but when mapping cams to suit, what else should be checked in order to know when you have dialed them in properly?
Cheers!
Dyno graphs....
Also, think I might have a sticking actuator, because boost peaked at 1.44 bar then dropped to 1.03 bar even tho I havn't played with boost, so will get that sorted before doing cams.
Old Nov 22, 2009 | 06:06 AM
todd6027's Avatar
extremely hard to tell what to adjust till you sort the actuator (evo8 one) and get the boost prob fixed .
you will see a different afr graph when thats sorted
Old Nov 22, 2009 | 12:31 PM
JohnBradley's Avatar
Herman,
Things stay the same just as always. Some things you might see are an increased likelihood of knock at the same boost level at a given rpm, fueling will change (typically need to be richened up), and depending on the size of the cams maybe a loss of torque down low.
Old Nov 22, 2009 | 05:52 PM
SoCal Rally's Avatar
Originally Posted by JohnBradley
... depending on the size of the cams maybe a loss of torque down low.
Yeah, if you want to keep torque down low (at the expense of some hp up high), look for cams with a rally-style profile rather than cams with a drag-style profile.
Old Nov 22, 2009 | 07:20 PM
rolly1818's Avatar
Registered User
typically for idle stability timing is added right?
sevic69
Aug 8, 2015 11:53 AM
Pirana
Mar 29, 2015 04:15 PM
SwiftEVO
For Sale - Cars For Sale
May 7, 2010 01:39 AM
Td66
Feb 21, 2009 01:03 PM
jdmxero055
For Sale - Part Outs
Oct 8, 2008 05:37 PM
