600whp capable on stock ecu?
Old Nov 25, 2009 | 06:59 PM
3gEclipseTurbo's Avatar
so im going for 600whp, so will the stock ecu be able to handle it or do i need to go stand alone?
Old Nov 25, 2009 | 07:01 PM
diiirk@AwdMotorsports's Avatar
Stock ecu can and has handled much more than 600 hp.
Old Nov 25, 2009 | 07:29 PM
bboypuertoroc's Avatar
Veteran: Army
Talk to Mellon.
Old Nov 25, 2009 | 11:23 PM
JohnBradley's Avatar
Old Nov 26, 2009 | 12:34 AM
sub7's Avatar
Madness! 8500rpm is max safe for stock evo or 2.2 stroke?
Old Nov 26, 2009 | 12:54 AM
That pull doesnt reflect it on the dyno sheet but the log shows a full pull to 9k
Old Nov 26, 2009 | 04:19 AM
3gturbo's Avatar
I laughed pretty hard when I read that. Even with cams your sohc motor wont do 600hp. It doesnt flow enough for anywhere near that. Evo head cams etc then you will need to upgrade the trans I broke mine 5 times at 350whp so needless to say you wont get 600 out of it. BTW your looking at spending 12k+ to get anywhere close to that. Also its fwd what are going to do with 600hp you cant put it to the ground.
