EvoScan won't log injector duty %
Old Dec 13, 2009 | 05:20 PM
Appauldd's Avatar
Anyone have any idea why EvoScan v2.6 won't log Injector duty % ? ? ?
Old Dec 13, 2009 | 08:28 PM
Evo_Jay's Avatar
make sure that IPW is also being logged and right above IDC in the list of items in evoscan
Old Dec 13, 2009 | 09:19 PM
Appauldd's Avatar
It is set correctly in the box you speak of. Also the IPW is being logged as well.
I try to log injector duty....nothing logs at all. Stays 0.
Old Dec 13, 2009 | 09:22 PM
Appauldd's Avatar
Is this correct for trying to log Injector Duty % ? ?
[InjPulseWidth]*31.25*x/1200
Old Dec 13, 2009 | 09:41 PM
Evo_Jay's Avatar
Yeah thats correct.
Are you sure that IPW is above IDC in the list of item in Evoscan? If its not, it wont log IDC. It will just have 0's like your experiencing.
Old Dec 13, 2009 | 09:45 PM
Appauldd's Avatar
There we go....pulse width was below duty %.
I knew it had to be something dumb.
Thanks for your help.
Old Dec 13, 2009 | 09:47 PM
Evo_Jay's Avatar
Np.
Old Dec 14, 2009 | 04:14 PM
vmrevo9's Avatar
Veteran: Air Force
hey quick question, i'm having an issue with logging load and i had added to evoscan the data for an omni 4 bar map sensor and w/b through ECU. now my load in infinity in my evoscan 2.0 and in my evoscan 2.6 beta19 it reads 0. i have moved the load from its orginal spot from the list to so i dont know what happened. any thoughts?
Old Dec 14, 2009 | 05:27 PM
Appauldd's Avatar
Upload the v2.6 of EvoScan....your problem should be solved.
Old Dec 14, 2009 | 06:08 PM
vmrevo9's Avatar
Veteran: Air Force
ok i'll give that a try. although i have never had an issue with load before until i did the patch for the map sensor. where can i find a link to download 2.6 if i'm already registered?
Old Dec 14, 2009 | 06:14 PM
Appauldd's Avatar
http://www.limitless.co.nz/
Give it a shot.
Old Dec 14, 2009 | 06:16 PM
vmrevo9's Avatar
Veteran: Air Force
i did but it ask to pay/register again? so do you have to pay for every copy of evoscan you download? i thought once you registered you can get updated copies for free?
Old Dec 14, 2009 | 06:18 PM
Appauldd's Avatar
It should ask for your email and such....if you registered before, it will be free for the updates.
Old Dec 14, 2009 | 06:27 PM
vmrevo9's Avatar
Veteran: Air Force
it only gives me the option for paypal unless i'm doing it wrong.
Old Dec 14, 2009 | 06:36 PM
vmrevo9's Avatar
Veteran: Air Force
well i decided to move the load calc around on the list and i saw a snap shot of the list on their site and placed the load under afrmap and now its reading in my 2.0v and i did not move anything around in the 2.6 beta and it works now as well. i'll do some logging again tomorrow and i'll see what happens then. thanks for the info!
