EvoScan won't log injector duty %
Anyone have any idea why EvoScan v2.6 won't log Injector duty % ? ? ?
make sure that IPW is also being logged and right above IDC in the list of items in evoscan
It is set correctly in the box you speak of. Also the IPW is being logged as well.
I try to log injector duty....nothing logs at all. Stays 0. |
Is this correct for trying to log Injector Duty % ? ?
[InjPulseWidth]*31.25*x/1200 |
1 Attachment(s)
Originally Posted by Appauldd
(Post 7795977)
[InjPulseWidth]*31.25*x/1200 Are you sure that IPW is above IDC in the list of item in Evoscan? If its not, it wont log IDC. It will just have 0's like your experiencing. https://www.evolutionm.net/forums/at...1&d=1260769296 |
There we go....pulse width was below duty %.
I knew it had to be something dumb. Thanks for your help. |
(Post 7796033)
hey quick question, i'm having an issue with logging load and i had added to evoscan the data for an omni 4 bar map sensor and w/b through ECU. now my load in infinity in my evoscan 2.0 and in my evoscan 2.6 beta19 it reads 0. i have moved the load from its orginal spot from the list to so i dont know what happened. any thoughts?
Upload the v2.6 of EvoScan....your problem should be solved.
ok i'll give that a try. although i have never had an issue with load before until i did the patch for the map sensor. where can i find a link to download 2.6 if i'm already registered?
i did but it ask to pay/register again? so do you have to pay for every copy of evoscan you download? i thought once you registered you can get updated copies for free?
It should ask for your email and such....if you registered before, it will be free for the updates.
it only gives me the option for paypal unless i'm doing it wrong. :crap:
well i decided to move the load calc around on the list and i saw a snap shot of the list on their site and placed the load under afrmap and now its reading in my 2.0v and i did not move anything around in the 2.6 beta and it works now as well. i'll do some logging again tomorrow and i'll see what happens then. thanks for the info!
| All times are GMT -7. The time now is 04:51 PM. |
